when i burned a dvd and examined in disk properties, it shows zero as used space. but it plays on standalone dvd player. normally it should show the used space and free space. why this. kindly suggest.
	Normally, unless you're burning a multi-session DVD or a DVD-RW, the disc is closed/finalized, so you can't write to it again - therefore, no more free space.
 DVD players may also have problems with multi-session DVDs (they might not see more than the first 'session,' if any), so it may not be a good idea to create such a disc for use with a DVD player. Some have reported that it works with their players, but it's always a good idea to test - and if you're going to create a disc for use with more than one player, it might be better just to avoid creating a multi-session disc.If cameras add ten pounds, why would people want to eat them?
	thanks . but my question was about a video dvd. while viewing its properties it should show the free/use space.
	How is a disc you can't (or can no longer) write to supposed to have free space?
 It should show how much data the disc uses, yes, though on a commercial disc, protection schemes might cause a computer to misread those figures. Why your computer would be having difficulty seeing the used space on a disc you burned, I couldn't say. Can you read the properties of the files (individually, or as a group) on the disc properly, on your system?
 Maybe it's burned in a UDF format that your Windows setup doesn't entirely understand.If cameras add ten pounds, why would people want to eat them?
  Burning software that shows exact space remaining?By nerv2112 in forum Authoring (DVD)Replies: 3Last Post: 27th Nov 2010, 21:34
  Burned DVD shows upside downBy sunilr41 in forum Authoring (DVD)Replies: 2Last Post: 12th Feb 2009, 03:59
  Is VCD/DVD disc space limited by time, or space?By pingosimon in forum MacReplies: 6Last Post: 14th Jul 2007, 20:55
  DVD compression, need more space!By SnakeDoc in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jul 2007, 21:44
  Baffled!! Titlewriter shows nothing but DVD Player shows Movie NameBy Subhash in forum Authoring (DVD)Replies: 16Last Post: 25th May 2007, 13:02
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
