I wasn't sure if my question belongs in here or the vid conversion forum but here goes nothing...
So, I'm trying to backup some concert DVDs but I'm having a hell of a time with it because they are interlaced. I usually use Handbrake for my backups which works well most of the time. However, for these concerts its decomb isn't cutting it and the deinterlace settings drop the quality too much. I've lurked on here and the Virtualdub forums for about a week trying to learn how to use DGIndex and AVIsynth, but I just can't get the quality where I want it and I don't really have enough knowledge troubleshoot. I've tried, really! Now I must ask for help.
I've uploaded a small portion of the source. If someone could take a look and offer some advice (or better yet, figure it out and tell me what they did), I would be SO grateful.
Thanks.
Source clip here: http://www.mediafire.com/?3d0kcxk5awrfsr5
Results 1 to 14 of 14
It's a PAL to NTSC conversion with blended fields. Use this:
Mpeg2Source("sample.d2v", CPU=2)
Yadif(mode=1, order=1)
SRestore() -
but parts of it look like pure interlaced NTSC with no blends
only the intro credits seem to have clear blends -
Yep, I agree. The credits up to about the 40 second mark are more-or-less standard field-blended PAL2NTSC. It looks to me that for the rest of it additional fields were created by interpolating and it's now true NTSC interlace. Using a script that produces 25fps also creates a jerky playing video. Bob it and then check the fields as the conductor is greeting the orchestra members. The violin bows are blended, but not in a way that lends itself to unblending. And there are no paused fields as there would be with field-blended PAL2NTSC. That's why I think additonal fields were created.
If it has to be made progressive at a single framerate, I think that framerate should be 29.97fps using something like:
Yadif(Mode=1)#or the bobber of your choice
SRestore(FRate=29.97)
Or even just a single-rate deinterlacer.
If for DVD I think I'd leave it interlaced since those credits make up so little of it. -
Wow, everyone, many thanks for your input.
Just to make sure I get it right, how exactly do I employ the suggestions that you've made?
Perhaps I should add that my goal is to encode these discs to x264 MKVs with AC3 5.1 passthrough.Last edited by winstonoboogie; 24th Oct 2010 at 00:02.
Earlier you said that Handbrake's deinterlacers didn't produce good quality output but weren't specific about what the problems were. Orchestra concerts can be tough to deinterlace because of all the fine diagonal lines, like from violin strings, so you get a lot of aliasing. If this thing is to be made progressive you have to deinterlace. The best are the AviSynth deinterlacers. jagabo and I used Yadif because it's fast and produces reasonable quality output. But it will have problems with aliasing. Better quality deinterlacers won't have the problem, with the drawback that they can be very slow to work their magic.
SRestore can be found here:
http://avisynth.org/mediawiki/Srestore
Yadif can be found here:
http://avisynth.org/warpenterprises/
But if you find it's not doing a good enough job, then try QTGMC:
http://forum.doom9.org/showthread.php?t=156028
It should take care of the aliasing and any other problems. But it will be slow to very slow, depending on the settings used. How badly do you want to do right by your concert? -
The problem with Handbrake deinterlacing seems to be that it tosses out too many frames, creates noise, and retains aliasing, which is especially apparent (as you said) on this video because there are lots of lines and fast movement.
Quality is of the highest concern here. I don't mind if it's slow. I also really want to learn how to deinterlace properly for future reference.
I read the QTGMC link, downloaded all the files, but the QTGMC download was just a script. Shouldn't there be a .dll for it? Like I said, I know my way around this stuff pretty well, but I have little experience using AVIsynth successfully and even sparser experience with scripting. I would value some slightly more verbose instructions as to how to properly set up and use QTGMC. I downloaded and extracted the contents of all the required files for it to my AVIsynth's plugins directory. But as for how to craft a script to use it, I'm a bit of a novice.
Let me know how I can help you help me!Last edited by winstonoboogie; 24th Oct 2010 at 07:16.
QTGMC is only a script. It uses a bunch of other AviSynth plugins (dll's). Download and install all those plugins (listed in the "reference" section) then you can use QTGMC in you own scripts. If you put QTGMC.AVSI and all those plugins in AviSynth's plugins folder they will automatically load when AviSynth is invoked.
Your script (a plain text file with the extension .AVS) will end up looking something like:
WhateverSource("filename.ext")
QTGMC(preset="slow") -
EDIT: I think I've got it. Had to clear out my plugins folder and re-install everything.
Now, one other minor problem. I'm recompressing with x264vfw in VDubMod, here's my command line:
--ref 6 --no-fast-pskip --bframes 6 --b-pyramid normal --direct auto --deblock -2:-2 --subme 10 --analyse all --trellis 2 --aq-strength 1.2 --psy-rd 1.0:0.0 --b-adapt 2 --me umh --merange 24Last edited by winstonoboogie; 24th Oct 2010 at 07:59.
Me, I don't do much x264 encoding, and when I do I use XviD4PSP. jagabo and especially poisondeathray should be able to help there.
You might first test the script using Yadif. Open it in VDub(Mod) and step through it to check if the script is good and if the results satisfy you. Then substitute QTGMC to see if you like the results better. Go to some places that were problematic with the Handbrake output. Or make some test XviD AVIs using VDub to get an idea of the encoding speeds and the results. If you get any error messages you can't figure out, post them here together with your complete script. -
Ah, of course, because it's NTSC anamorphic. I needed that 40:33 in there.
QTGMC looks great!
Thank you all so much for your help.
Desperately seeking R2D2 region hack!
By Purpleyez in forum DVD & Blu-ray PlayersReplies: 18Last Post: 3rd Jan 2013, 04:44 -
Help desperately needed with HDD problem
By jeanpave in forum ComputerReplies: 28Last Post: 17th Jul 2011, 22:41 -
Microsoft desperately seeking the Magnificent Seven
By ahhaa in forum ComputerReplies: 3Last Post: 14th Feb 2009, 09:09 -
Desperately Seeking Help! Home Theatre problem
By jbsbubby in forum Newbie / General discussionsReplies: 12Last Post: 4th Jan 2009, 21:08 -
Desperately need some help with Dr Divx 1.6 (old version)
By nerys in forum DVD RippingReplies: 10Last Post: 12th Sep 2008, 07:48
