Most of the video converter and encoders fails to convert following video clip and output to AVI or any other format has audio and video out-of-sync. However, video has been re-muxed by correcting audio timebase.
General
Complete name : Annual Farewell.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
Duration : 55mn 57s
Overall bit rate : 698 Kbps
Video
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 55mn 57s
Bit rate mode : Variable
Bit rate : 564 Kbps
Maximum bit rate : 549 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 30.000 fps
Original frame rate : 29.970 fps
Minimum frame rate : 29.412 fps
Maximum frame rate : 55.556 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.057
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Duration : 55mn 57s
Bit rate : 192 Kbps
Maximum bit rate : 224 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
is it the variable fps video and variable bitrate audio generates ou-of-sync issue?
yes. 2 strikes against that one and your not going to have any fun, variable video framerate and vbr audio. demux and convert both to constant frame rate video and constant bitrate audio.
Ripboot after conversion video & audio sync is out by 1 seconds ???
By yamyoume in forum Video ConversionReplies: 5Last Post: 17th Oct 2011, 15:32 -
Audio & video out of sync
By gaboone in forum Newbie / General discussionsReplies: 1Last Post: 25th Mar 2011, 22:21 -
Video & Audio is out of sync after muxing
By Spettro in forum EditingReplies: 2Last Post: 2nd Dec 2010, 12:11 -
Funky Audio & Video Sync Problem [FRAPS]
By Sniff211 in forum Video Streaming DownloadingReplies: 12Last Post: 7th Jul 2010, 10:05 -
Audio & Video In Sync
By marioval in forum Authoring (DVD)Replies: 22Last Post: 22nd Oct 2007, 19:13
