Hello all
I am looking for advice on which USB Tuner/Capture Device to get. I need a USB 2.0 tuner that will accept analog connections(because I'm going to use it mostly for VHS transfers), that is capable of capturing a VHS tape at the identical quality of that VHS tape, that will work in both OS X and Windows 7, and that costs (hopefully) in the $60 range. I don't think I will need any digital tuner capability. The EyeTV Hybrid looks nice, but $200 seems steep to me. Any advice is appreciated.
See Elgato. One model there has tuner and analog inputs.
http://www.kiva.org/about -
For capture only (no tuner):
There's this from Elgato
http://www.amazon.com/Elgato-Video-Capture-Device-White/dp/B0029U2YSA/ref=sr_1_1?ie=UT...7876001&sr=8-1
And the EzCAP116, also witout a tuner: http://www.ezcap.tv/
http://www.amazon.com/EzCAP116-Camcorders-Recorder-Satellite-playstation3/dp/B003YGJLW...1033643&sr=8-1
The EzCAP requires the purchase of VideoGlide software for use with a Mac, which means the two options are closer in price than it seems at first glance
http://www.echofx.com/videoglide.html
I haven't tried either, but Elgato has a good reputation and is probably worth the extra cost.
I saw nothing with an analog tuner near your price-point.
Looking for a USB Video Capture Device I can work with in VB.Net
By Snakebyte1 in forum Capturing and VCRReplies: 0Last Post: 6th Oct 2011, 07:59 -
Can someone recommend a good USB style tuner device for me
By True Colors in forum Capturing and VCRReplies: 0Last Post: 31st Jan 2010, 14:12 -
A Good USB Capture Device?
By hech54 in forum Capturing and VCRReplies: 5Last Post: 23rd Dec 2007, 02:23 -
USB device capture
By ramin in forum Capturing and VCRReplies: 1Last Post: 15th Nov 2007, 14:48 -
USB Capture Device
By gruberted in forum Capturing and VCRReplies: 13Last Post: 11th Jul 2007, 13:56
