I have hooked everything up...my vcr through the ADVC 110. I understand that while capturing analog video, the WinDV123 does not play the audio...however, in playback, I have no audio. I've checked the properties on my recorder, they say "Input audio"...what other settings do I need? This device is supposed to be pretty much plug and play. When I play stuff from youtube, I hear the sound just fine...so I know I have sound. I shouldn't have to purchase an audio capture card, should I? I've tried using Windows Movie Maker, WinDV123 and Virtual Dub, nothing works. Your help is appreciated.
I tried both of those...turns out, the solution was the settings on the VCR itself. Since the type of stuff I'm capturing is old songvids, done back in the day on VCRS, then the audio settings need to be set to "Mixed" or "Normal" not Hi-Fi...so I messed with that, and then set it to TYPE II and VOILA. I deserve a brownie and so do you! Thanks! All my sound shows up on playback now.
http://www.kiva.org/about
Canopus ADVC110 w/Power Director audio stutter problems when capturing?
By popflier in forum Capturing and VCRReplies: 7Last Post: 6th Mar 2010, 03:48 -
Canopus ADVC110 or other converters
By pdx10 in forum Capturing and VCRReplies: 3Last Post: 13th May 2009, 13:35 -
ADVC110 to Studio 10 Capture
By jimlong in forum Capturing and VCRReplies: 3Last Post: 16th Aug 2008, 08:41 -
Brightness fluctuation problems - capt from VHS thru ADVC110
By ChrisMtl in forum Capturing and VCRReplies: 18Last Post: 7th Dec 2007, 13:47 -
Viewing TV using Canopus ADVC110
By cblmdm in forum Newbie / General discussionsReplies: 1Last Post: 3rd Oct 2007, 21:22
