As per the subject, I'm looking for suggestions on the best file type to convert .trp/.ts files to for editing in Final Cut.
My PVR captures HDTV and on the HD it saves as multiple .trp files (each is 1.58GB).
What I would like to do is
a) Keep a single file (which joins all the files) which is excellent quality (i know this is subjective and based on taste, but im looking for suggestions atm)
b) Keep either a seperate file or the same file where if I feel like editing the video for further use then I still end up with a relatively high quality video in the end
THe footage ive captured is 3hr basketball games currently at around 25-30G each. My ideal file size at the end would be around 5G - hopefully this is enough to maintain excellent quality.
	I haven't used Final Cut, but DNxHD is a popular codec for HD editing. The file sizes would be big for several hours of HD footage - but you wouldn't keep the DNxHD files after editing.
 That would make your original video ~20Mbit/second, and you want to reduce it to about 3.8Mbit/s - which isn't really enough for good quality HD video. Depending on the content/frame-rate/resolution, I would aim for 8-9Mbit/s h264(AVC) - around 12GB for 3 hours.THe footage ive captured is 3hr basketball games currently at around 25-30G each. My ideal file size at the end would be around 5G - hopefully this is enough to maintain excellent quality.
 Also, I think Windows has a limit on file sizes of 4GB (for Fat32 file systems) which would limit what you're trying to do. Hopefully your computer uses NTFS instead.
  Help! How to convert mpeg-2 file with LPCM audio to Final Cut Pro?By afireinside181 in forum Video ConversionReplies: 3Last Post: 31st Oct 2011, 19:59
  Issues Editing Skype's .MOV's in Final Cut Pro.By macphoto in forum EditingReplies: 1Last Post: 14th Sep 2011, 21:18
  Help !!Convert a trp file with Mpeg streamclipBy caliman in forum Video ConversionReplies: 0Last Post: 21st Oct 2010, 12:55
  How to convert a trp type file to Mpeg2 type?By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 16:59
  transcode avi with cdvc codec to dv sd for editing in final cutBy raulamado in forum MacReplies: 3Last Post: 13th Oct 2008, 03:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
