I may have posted in the wrong group. So I am re-posting here.
Hi,
I tried to save a clip as wmv in Movica, but got a message that asfbin
was out of date.
I downloaded the latest version (Windows AsfBin Command line version
1.7.14), copied it to the Movica directory, but now I get a message
calling for more files. I did not get these messages before.
Can anyone advise.
A
Ps. OS is Vista, 32bit
				Results 1 to 20 of 20
	Please don't cross post. If you wish a topic moved, PM a Mod. Duplicate deleted.
 Moderator redwudz
	Anon_private:
 1 - If you have successfully used Movica before, check whether you had recently installed any new software which may have interferred.
 2 - Which version of Movica are you using? I could not run Movica 6.6 with Vista, but Movica 5.0 did work.
 3 - Try to reinstall Movica
	Something I forgot to ask.
 When I downloaded the latest ASFBIN file I downloaded the version for Windows that works from the command line. I use Windows. Must I use the command line? Previously, I never used the command line. The other Windows version on the website seems to have bug utilities included.
 Have I downloaded the correct version for someone who uses Vista 32 bit?
 I can't see any other suitable version on the radioactivepages site.
	A:
 You don't need to manually install asfbin, and, the command line version may differ from the GUI version. It is installed as part of the package with Movica.
 May I suggest to uninstall the current version of Movica and the manually installed asfbin then re install a freshly downloaded Movica 6.6 or 5.0.
 If no luck you may consider uploading a sample clip for us to look at.
	Thanks for responding.
 I have uninstalled the current version of Movica and have re-installed 0.6.6.1 from SourceForge.
 I still have the probelm.
 I have tidied up the logfile a little and present it below for comments:
 Using converter : C:\Program Files\Sourceforge\Movica\asfbin
 With arguments : -i "C:\Users\A\Downloads\Frank S Video _By Don - Something_1.wmv" -o "C:\Users\A\Downloads\Frank S - Something_11.wmv" -start 0 -stop 25.324 -start 156.579 -stop 158.617 -details -y -rkf
 Please wait...
 Detailed results will follow:
 Conversion Failed !!
 ASFBIN - version 1.6.1.703. Copyright 2001-2007 by RadioActive.
 Non-commercial version.
 Visit www.radioactivepages.com for latest updates.
 Input file list:
 File no. 01: C:\Users\A\Downloads\Frank S Video _By Don - Something_1.wmv exists
 Segments to copy:
 Segment no. 01: start = 00:00:00.000, duration = 00:00:25.324,
 Segment no. 02: start = 00:02:36.579, duration = 00:00:02.038,
 PROCESSING FAILED!
	I have had a similar problem with Movica 6.6 and Vista.
 1 - Could you try any version of Movica on Windows XP or Windows 7. If that was successful then the culprit is Vista
 2 - In Vista:
 Could you uninstall Movica 6.6 and try Movica 5.0 version.
 Make sure that only one instance of Movica is active [ check the Task Manager ].
 3 - There may be a subtle encoding bug in one of your "segments". You check this by trying to save another segment farther a way from the one you want to save e.g start 26 stop 36.
 Again it would help if you could upload a sample of your clip [ try mediafire.com ]
	I only have access to Vista.
 I could try Movica 5.0. Have you had success with this version under Vista?
 I'll try and check for eny encoding bug.
 Why would it help to view the clip. It looks alright to me. Just can't save it as wmv?
 I like the the site you have listed (mediafire.com).
 I'll get back once I have had a chance to try out a few things.
 In the meantime if anyone has any further suggestions please let me know.
 Best wishes.
 A
 Ps. I note at the foot of this reply box a link ('Upload files/Manage attchments'). What type of file is supported - size, etc?
 It probably failed because you didn't rename the file
 30MB , it tells you the valid extensions right beside the upload files button:Ps. I note at the foot of this reply box a link ('Upload files/Manage attchments'). What type of file is supported - size, etc?
 Valid file extensions: 7z aac ac3 asf avi avs bmp dmg doc dts exe flac flv gif jpeg jpg log m2ts m2v m4a mkv mov mp2 mp3 mp4 mpa mpv msi mts ogm pdf png psd rar srt sub ts txt vob wav wma wmv xml zip
 or you can use a free hosting site e.g. mediafire.com, sendspace.com , many others
 I thought that I changed the file name!
 But I will retry and change it completely.
 Best wishes.
 A
	poisondeathray.
 I have tried to save the file using a different name, but the save failed. I then changed the directory for saving and again the save failed. I got the same 'exists' message in both cases.
	No, I could not save other segments ('exists' message persists).
 Best wishes.
 A
 Ps. I have downloaded (not installed) another asfbin.exe pack. This pack contains asfbin.exe as before (same md5 sigs), but this time also contains asfbinapp.exe (not installed). Do you think that this latter application might help to solve my problem. I assume that it should be copied to the Movica directory.
	Using Movica 6.6.1 on Vista, if you have successfully opened, cut and saved segments from OTHER WMV FILES then the fault lies with your current video file. If you have not done that before, get some other WMV clips and see if it works
 I don't think manual installation of asfbin files is necessary, but you could try.
 Have you tried Movica version 5?
 I think the problem may lie in the file.
 I have tried a basic repair with asftools with success.
 The problem with using asftools under Vista 32 bit seems to result in corrupting this repair programme after use.
 Have you any experience with asftools under Vista 32 bit. In particular avoiding corrupting this programme after use.
 Best wishes
 A
 Ps. If you have come across a better repair utility under Vista, let me know, it could be useful
	Sorry I don't have any experience with asftools.
 You can try Windows Media File Editor, which comes as part of Windows Media Encoder.
  Saving Clips as wmv Files Using Movica Under Vista 32 bitBy anon_private in forum Off topicReplies: 0Last Post: 24th Oct 2010, 12:21
  combining WMV movie clips into one WMV clipBy blkwht240 in forum EditingReplies: 3Last Post: 5th Feb 2010, 01:41
  Movica 6.6 beta - spyware? joining few wmv files & wants to contact GooBy suzanne27 in forum Newbie / General discussionsReplies: 3Last Post: 28th Sep 2009, 18:15
  downloading a segment of a wmv file?By kruuth in forum Video Streaming DownloadingReplies: 0Last Post: 15th Apr 2008, 22:28
  How to convert wmv clip so its properties match other wmv clipsBy sohaibrazzaq in forum Video ConversionReplies: 4Last Post: 4th Aug 2007, 10:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
