  1. Hi i have a 23" HP Monitor. I want to be able to watch cable tv on it through HDMI (i have a cable box with the hdmi output but not one upstairs). Will I be able to do this with this tuner box? And is there any way to do it at all?
    http://www.bestsellerhdtvs.com/review-kworld-hdmi-dvi-vga-qamatsc-external-digital-tv-tuner-box-hdtv
  2. Maybe. Does your monitor support standard HDTV resolutions? 1280x720p60, 1920x1080i30?
  3. Yes, right now i have my xbox 360 hooked via hdmi
  4. Sounds like the tuner box should work. You'll only be able to watch unencrypted QAM channels and over-the-air (with an antenna) broadcast channels -- usually pretty much the same channels.
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    An ATSC/QAM tuner like the one shown will only get a limited set of "clearQAM" cable channels usually limited to locals + a few shopping channels. It won't tune analog channels or encrypted cable channels.
    You will also probabaly be limited to 1280x720p/59.94 ove HDMI. Most computer monitors lack support for interlace.
    To get all the channels, you will need to rent an additional HD cable box (~$8/mo).
    http://www.kiva.org/about
