I’m new to this board and VERY new to cutting/burning DvDs, so please bear with my ignorance.
I’m wanting to get a 2-minute clip from a video on DVD that is nearly an hour long. I’m then wanting to post this 2-minute clip on YouTube. Unfortunately, the hour-long video, which consists of VBO files, has only one chapter – which is the entire video itself, so I couldn’t use my normal video cutter – Hand Brake.
I downloaded DVD-lab PRO 2 because I read where chapters can be inserted into the video. However, it seems like DVD-lab PRO 2 will only burn a DVD when all I simply want to do is merely clip a small video from a large one – no DVD – and get just a file I can then upload on YouTube.
Anyone familiar with DVD-lab PRO 2 know how I can save what would be burned onto a DVD, instead be saved as a video file on my PC? Is there a FREE program out there that would be better than what I’m currently using for what I’m trying to accomplish?
Any feedback would be greatly appreciated. Thanks!
Ranger
Results 1 to 14 of 14
I think the simplest way is the free dvd shrink in reauthor mode. You open the disc and go into reauthor mode. Then drag the title over to the main tab and go into the chapter cut window. From there just grab the segment you want. You can rip it to the harddrive then.
If this is a commercial dvd you'll need to rip it first probably. Dvd shrink is VERY old and has not been updated in forever. Use the free version of dvd fab decrypter and copy as a video_ts. Then in dvd shrink use open files and find the folder where you saved the disc.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Vob2mpeg to extract the video from the dvd (rip first as above if commercial)
mpegstreamclip or vdubmod to extract just want you want
upload the extracted clip to youtube -
Thanks guys for all your help! I was able to rip the clip to my harddrive with your suggestions.
So, I was able to rip VBO files into small clips using DVD Shrink 3.2. Now, I'm wanting to combined these small video clips into a larger clip. It doesn't appear DVD Shrink will combine or merge clips (but I might be mistaken)... Any suggestions to accomplish this?
dvdshrink can combine them. put it in reauthor mode. in the right pane navigate with the dvd browser to a clip and then drag it to the left pane. continue for each clip. click the backup button at the top when done.
Hope your problem is already solved with the help from all the experts above.
DVDShrink is also one of the best DVD Chopper. DVDShrink normally creates the folder in root by default with same label as DVD and file same as VTS_xx.VOB
As chopped VOB is high resolution, make sure you upload very High Res clip to YouTube as well to be viewed by maximum numbers of the viewers. HD profile 1980x1020 v-bitrate =5500kbps plus - audio AAC 224 kbps stereo 2 ch. Use Free HDconverter. -
aedipuss, thanks again for your help. I did exactly what you said...I dropped the three clips I'm trying to combine (2 for one disc and 1 from another) in the left pane, ran "Backup!" and the program encoded the three clips together (apparently, so far, so good). However, when I go to the output folder, the clips aren't merge into one larger video file but instead the three individual smaller clips...
In case it helps I use Womble's Mpeg video wizard to cut scenes ....frame accurate cuts and joins and transition effects and you can get a free trial.
Thanks for everyones help! I finally figured things out thanks to your suggestions...
DVD Lab Pro help! Play animation after pressing button for playing video.
By visualhippocracy in forum Authoring (DVD)Replies: 3Last Post: 26th Mar 2011, 09:21 -
DVD-Lab Pro 2: How to set a looped video as background of a menu?
By Stern77 in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2010, 12:00 -
video tutorial dvd-lab pro
By waefwaeefwaefw in forum Authoring (DVD)Replies: 1Last Post: 27th Oct 2008, 11:53 -
video size quadruples in dvd lab pro
By YOURCONNEXX in forum Authoring (DVD)Replies: 1Last Post: 13th Mar 2008, 20:23 -
loop entire video in dvd lab pro?
By sarcastik in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2007, 20:04
