I want to switch to Blue-Ray in the future even though I don't like it because to many changes to it. Every new release something happens, looks like they change the specs every month
I am kind of confused right now which is the better codec to use: Mpeg2 or H.264. I would choose H264, but I just want to make sure this is the right way. I think that Mpeg kind of had his time.
I want to sell my SD Canon GL2 and get a HD HDV and start using blu-ray.
h.264 is usually better if you use a good implementation and you are re-encoding, but beware, some avc encoders produce very poor quality
If you are shooting hdv, it is already blu-ray compliant (it's mpeg2). You can author the native streams as is. So if you use smart rendering software, and do cuts type editing, there is no generation loss either - this would be better than re-encoding. But if you are in a situation that requires re-encoding (e.g. global filters, color correction) , then h264 is usually better
H.264 back to blu-ray structure?
By jlm86 in forum Blu-ray RippingReplies: 8Last Post: 21st Feb 2011, 08:19 -
Blu ray output to H.264
By mobie29 in forum Authoring (Blu-ray)Replies: 1Last Post: 7th Feb 2011, 15:47 -
Premiere CS3 HDV to H.264 Blu-ray
By foochuck in forum Video ConversionReplies: 5Last Post: 24th Nov 2009, 11:32 -
Blu-ray encode to h.264 - Audio Problems
By sangood in forum Blu-ray RippingReplies: 5Last Post: 25th Apr 2008, 07:32 -
How to encode H.264 for HD-DVD and Blu Ray ?
By p6889k in forum Video ConversionReplies: 12Last Post: 17th Jul 2007, 01:08
