Hi people - hope you can help.
I am having great difficulty getting PS3 to recognise audio from my conversions.
I am using 720p MKV file - H264/DTS. This is what I am doing (after many days of googling).
1) Tsmuxer - demuxing video and audio from MKV file. I am left with h264 and dts files.
2) Converting dts audio to ac3 (also adding speedup and downsample to 2-channel) using command "eac3to example.dts example.ac3 -speedup -down2". This outputs an ac3 file as promised.
3) Muxing to m2ts using Tsmuxer, changing frame rate to 25fps for video.
When i finally play this on PS3 - video is fine, it also recognises AC3 2 ch audio - but it is STILL out of sync.
Is there any other method to speedup the ac3 file?
The reason i downsampled to 2ch is that every single 5.1 audio track i have tried isn't recognised.
I would really appreciate any advice on this.
Why are you doing "speedup"? just because you are "GB" doesn't mean you have to change to PAL.
Try this:
install this: http://www.dvduk.pwp.blueyonder.co.uk/_files/rebox.NET.beta2.zip
right click the "mp4" button, select "TS", your file will be converted and ready to play on the PS3 in minutes. -
I am speeding up because my tv doesn't properly support 24p and suffers from judder. Any local files/streamed files to ps3 default in 60hz. Converting to 25fps forces PS3 to run in 50hz, which would result in smooth picture.
I will check the link. -
Hi flexx
I have the similar requirement and use this https://www.videohelp.com/tools/GOTSent, thick the "25 fps OUTPUT" from the GUI and it will speed up the movie for you. If you copy the files through a FAT32 HDD then this app can also split the files to smaller then 4GB for you.
Only thing is I don't know how this would output surround sound as I output stereo only.
Hope this helps
CheersLast edited by thisisjimmi; 17th Nov 2010 at 06:34.
MKV with DTS-HD to PS3
By tge101 in forum AudioReplies: 17Last Post: 21st Apr 2011, 09:50 -
Converting an 1080p MKV (AVC1 H264 with DTS audio) to an AVI
By cpaqf1 in forum Video ConversionReplies: 5Last Post: 22nd Jun 2010, 21:50 -
PS3 playback of MKV 1080i, 25fps > 23.976 source to BD plays at half height
By Zot in forum Blu-ray RippingReplies: 0Last Post: 29th Mar 2010, 17:00 -
24fps HD-MKV (H264/VC-1) to 25fps SD-MPEG2
By Nightwalker_z in forum Video ConversionReplies: 9Last Post: 27th Apr 2009, 09:31 -
Demux h264 .ts file for ps3 playback
By Doomed Space Marine in forum Video ConversionReplies: 1Last Post: 22nd May 2007, 03:42
