I was doing a routine "drag *.vob into DGIndex and save project" when I encountered this message for the first time.
So, I chose 'Yes' which gave :
DGIndex then made 3 files : movie.d2v (fixed file), movie.d2v.bad (uncorrected) and movie.fix.txt which contains :
I don't really know what all this means, but here's what I'm trying to do. The movie is fieldblended PAL to NTSC and I'd like to encode it as interlaced, to fit in a DVD5.D2V Fix Output
Field order transition: 0 -> 2
900 5 0 7030784 0 1 1 30 30 90 a0
900 6 0 7092224 0 2 1 92 b2 b2 a2 b2 b2 a2 b2 b2 a2 b2 b2 a2 b2 b2 a2
corrected...
900 5 0 7030784 0 1 1 30 30 90 a1
Field order transition: 2 -> 0
900 6 0 5854910464 0 3 10 92 b2 b2 a2 b2 b2 a2
d00 5 0 5855109120 0 4 1 90 a0 a0 a0 a0 a0 a0 a0 a0 a0 a0 a0 ff
corrected...
900 6 0 5854910464 0 3 10 92 b2 b2 a2 b2 b2 a3
The first *.vob is BFF according to mediainfo and GSPOT, the rest are all TFF. So, do I need to add anything to my avisynth script and what should I choose inside the advanced options of CCE ?
Results 1 to 1 of 1
do I have a field order problem ?
By davexnet in forum Video ConversionReplies: 9Last Post: 13th Dec 2010, 13:41 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 00:38 -
AutoGK and DGFix - field order transition
By Towin in forum DVD RippingReplies: 4Last Post: 7th May 2008, 19:15 -
Field Order Problem?
By GordRocks in forum Authoring (DVD)Replies: 3Last Post: 4th Mar 2008, 09:19 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 16:14
