I also bought easycap on ebay. The installation has not been straightforward. We're directed to plug in the hardware on the USB port, and then insert the CD. The MS install wizard does come up and, after going thru the Nexts, it looks like it installs--there is a syntek STK1150 service installed and running. Also, there is an stk1150 device listed in windows explorer. However, here's where it gets confusing. There's an autorun wizard that comes up with "Install DVR" as an option. When you click that option, another install wizard comes up for stk 1160 grabber. When you complete stk 1160 grabber install, you look under hardware properties "Sound and Video game controllers" as directed, "stk 1160 grabber" is listed, not "STK1160 ATV BDA." The instructions say if "STK1160 ATV BDA" is not listed, it's not installed. Also, after that second install, the stk1150 device is no longer listed in windows explorer.
Can anyone enlighten me? Some tips on use would help. I'm trying to convert 8mm tapes to DVD. There are few clear operational instructions.
It appears that somebody replied to you in another thread by mistake. https://forum.videohelp.com/threads/270720-Easycap-Video-Grabber-Capture-card-USB-2-0-R...=1#post2027062
Watch this tutorial and see if it helps with driver installation.
http://www.youtube.com/watch?v=Zbdz4HNtC-Y
If not, you could try the same method with other drivers. I can't promise that any of these will help, and as always, virus scan the downloads before installing.
Drivers are at the bottom of the page at this link: http://www.vidblasterus.com/accessories.htm
The drivers for Sabrent's USB 2.0 Video & Audio DVD Maker have also been reported to work for some EasyCap clones http://www.sabrent.com/drivers.php
If you are using Ulead Video Studio watch these for more help with getting audio working.
http://www.youtube.com/watch?v=ZI7yj...eature=related
http://www.youtube.com/watch?v=JwOJ65kzpdI
Tips: I haven't done it myself but as a member of this website, I have read about and seen plenty of examples of problems that crop up during transfers. It is frequently not possible to convert analog tapes to digital and get a good result using just a capture card.
Consider having any tapes that are especially important to you transferred professionally. Doing it yourself without the right equipment will most likely take a lot of work and yield results that don't look nearly as good as the original tapes. Though I haven't used them, this site http://www.digitalfaq.com/services/video-conversion-tape-to-dvd.htm offers such a service.
Will you be capturing 8mm tapes using an analog camcorder or a digital one to play the tape? If it is digital and you can't get anywhere using an EasyCap, you might be able to get the video onto a PC in DV format using fire wire. However, I can't promise the resulting video will be problem-free using this method either. Fire Wire cards cost little more than an EasyCap.http://www.newegg.com/Product/Product.aspx?Item=N82E16815265002&cm_re=firewire_card-_-...-002-_-ProductLast edited by usually_quiet; 22nd Oct 2010 at 17:48. Reason: clarity, spelling
EasyCap driver
By ronfarnham in forum Newbie / General discussionsReplies: 5Last Post: 1st Sep 2016, 21:04 -
Easycap DC60+ STK1150 vs. STK1160 driver
By ET3D in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2012, 08:02 -
EasyCap Video Adapter Driver for Windows 7 64-bit
By Naymark.com in forum Capturing and VCRReplies: 4Last Post: 26th Mar 2012, 01:08 -
Easycap 2.0 Installation.
By xAnonymousx in forum Capturing and VCRReplies: 2Last Post: 7th Jun 2010, 07:37 -
Easycap driver problem
By Jack_Dante in forum Capturing and VCRReplies: 2Last Post: 8th Feb 2010, 15:22
