I have a Sony HD camcorder.
Is there a program out there that does with AVCHD what Womble does for MPEG?
I simply want to be able to trim video and join video perhaps with a transition.
I don't want to do any conversions.
If possible the only other thing I would hope is to possibly insert chapters if possible.
That's it. Nice and simple. I like how Womble works with MPEG. Real easy, no conversion and fast.
Can this be done with the Sony AVCHD files?
Thanks.
Thanks jagabo. This seems like it will work nicely.... maybe....
I cued up some small files and no problem.
I tried to cue up about 10 2gig files.
My total output was 2 gig with parts of all 10 files.
Do you know if this a file size limited to the demo or the program itself?
I also just asked on their website but thought I might an answer quicker here since its Sunday.
If this is a program limitation are there any others that can do what I need?
Was also wondering if its possible to have some chapter points in these files without conversion?
One more thing... the files I mentioned above were part of one 3 hour long video so I would just want them joined.... possibly with chapters since it is such a big video.
But some vids wont flow seamlessly time wise. Is it possible to put transitions between videos or would this require some form of conversion?
Thanks!
AVCHD/.mts editing and conversion help?
By fox's box in forum Video ConversionReplies: 1Last Post: 20th Sep 2010, 04:00 -
Using proxy files for AVCHD editing - conversion software
By sterankin in forum EditingReplies: 27Last Post: 11th Jun 2010, 05:46 -
Conversion of AVCHD Lite to less compression for easier editing
By freeav in forum LinuxReplies: 18Last Post: 15th Oct 2009, 08:54 -
AVCHD editing help.
By zgrm100 in forum EditingReplies: 4Last Post: 23rd Dec 2008, 14:12 -
Canon HF10: AVCHD editing under Win2k, SD conversion
By artm in forum Newbie / General discussionsReplies: 3Last Post: 18th Jul 2008, 14:21
