Results 1 to 9 of 9
  1. well this might not be the correct place to ask this but:
    there is 1)Great Knowledge here and you 'flip' the pages fast on you eBook it becomes Very Old Fashioned video
    so if I have an eBook I own, is there a way to convert it to a .pdf to view on my computer?
    Reaaaalllllly Realllly fast, like a video?
    MPro 2.66 3GB RAM 1.5TB HD's
    MigliaMiniHD
    QTPro, MPEG2 add on MPlayerX2
    MPEG Streamclip
    24 + 21" samsung flat panels
    G4dual 2GB
    AlchemyDVR card
    USA
    I doubt it, unless you can convert it to a text format. An E-Book probably is encrypted if it uses a special player.
    Are you using a stand alone E-Book player or your Mac to view it? If you can extract it as text, you can probably use that to convert to .pdf. OS X should have a .pdf converter built in. (Though it may be a bit slow for a large conversion.) Check the output options for your text/word processor. There are also some freeware converters that will work with a Mac.
  3. Member terryj's Avatar
    N35°25.24068, W097°34.204
    second on Calibre, friend rotus. Just be careful to make sure that when converting, if your e-book has photos, not
    to strip them out.
    Another alternative is to use the Stanza reader on your mac, and simply "Print to PDF" using the built in PDF printer in OS X.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  4. Awffflllly good tips here!
    many thanks!
    MigliaMiniHD
    MPEG Streamclip
    G4dual 2GB
    AlchemyDVR card
    Pages'09 now supports exporting to ".epub". Apple has posted a document on how to do this properly. If you can't find it online, PM me and I'll post it for you.
  6. Originally Posted by rumplestiltskin View Post
    He wants to go from .epub to .pdf!
    D-oh! I must have been reading right-to-left.
  8. We all do that from time to time.
