hi im capturing audio from old reel to reel onto a cd recorder and im curious if theres a biut of hardware that i can place in beween units to enhance sound?
i guess what i mean by that is increase vol, and adjust tonal/base range at minimum
my budget is circa 200$
You can do better with computer software....free computer software too.
True but this will be post processing. You'll have to do realtime copying and burn the finalized disc. Then copy it to the computer and edit it.
Or if you want to skip the cd recorder step simply record to cd mode directly to your line input jack on the computer and save the cds.
If you want to do this in one shot live you'll need to get an audio equalizer. I have no experience with them so I can't offer advice. Basically it would go inbetween your reel and the cdrecorder. Than you can manipulate live the audio and then when its just right start over and record to disc - your adjustments will be recorded directly onto the cd.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
You might look at some of the Behringer products. For example a low cost (~$50US) equalizer: http://www.behringer.com/EN/Products/FBQ800.aspx There are a lot of other audio mixers, equalizers, etc. on their site that are reasonable priced. You can likely find them locally or on the net on maybe Amazon or E-bay or some on-line music stores. I believe the company is in Germany, so should be available in your location.
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12
