Hi All,
Is there any tool that i can use to convert any avs video file to YUV format. basically i am trying to decode the mpeg2 video stream in avs and in need to store the output into YUV format. is there any tool for this i am using avs2raw.exe but i am getting some Unsupported format error to convert. I can play this avs in VirtualDub.
fido
What do you mean by YUV format? Raw 8 bit per channel YUV 4:2:0 "I420" video like these?
http://media.xiph.org/ldv/pub/test_sequences/720p/
You can use GraphEdit and the Dump filter.Last edited by jagabo; 22nd Oct 2010 at 07:14.
MS-YUV - Sony Vegas
By francisco-drm in forum Capturing and VCRReplies: 2Last Post: 25th Nov 2011, 11:56 -
JPEG to YUV
By mma238 in forum Video ConversionReplies: 20Last Post: 3rd Apr 2011, 11:53 -
how do i take avs logo off avs video
By tnwolf35 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Sep 2010, 21:08 -
convert .yuv to .ts
By mrzapp in forum Video ConversionReplies: 3Last Post: 19th Nov 2008, 07:34 -
YUV viewer
By mourya in forum ProgrammingReplies: 0Last Post: 31st Oct 2007, 13:38
