I need to make a batch of videos that have a custom intro for each prospective client.
It also has two separate videos sections in the middle that are customized for each prospective client.
And... and ending that is customized for each prospective client.
Should I learn some sophisticated scripting tool/method... or is there a simpler way to spit out my 37 unique videos easier?
And if scripting is the way to go, any software recommendations/solutions?
Thanks.
If they are unique, and have no shared elements, you have to do each separately
Otherwise you can save and elements to make it faster (i.e. start from a partially finished project each time, and just replace the video section in the middle) -
You could create a dos batch file that will iterate through directory structures set up with all the unique clips for each client and using the paths of the directory structure, do a binary concatenation of the clips and pipe that into ffmpeg to output the full video.
Directory structure:
\MainVideo\
mainpart1.avi or mainpart1.mpg
mainpart2.avi or ...
mainpart3.avi or ...
\MainVideo\Client01\
intro.avi or ...
mid1.avi or ...
mid2.avi or ...
end.avi or ...
\MainVideo\Client02\
intro.avi or ...
mid1.avi or ...
mid2.avi or ...
end.avi or ...
Etc....
batch file
for /d %%a in (Client??.) do copy /b %%a\intro.avi + mainpart1.avi + %%a\mid1.avi + mainpart2.avi + %%a\mid2.avi + mainpart3.avi + %%a\end.avi | ffmpeg.exe -i - -vcodec copy -acodec copy %%a\%%a.avi
Run this batch file from the MainVideo directory. Just make sure your video format is something that ffmpeg can decode.Last edited by Khaver; 21st Oct 2010 at 11:53.
How to Remove Camera Shake from iPhone 4S Videos (Batch Deshaker Script)
By preshing in forum EditingReplies: 1Last Post: 17th Apr 2012, 23:35 -
quick question on power of Avisynth script?
By kopmjj in forum RestorationReplies: 4Last Post: 16th Apr 2010, 23:36 -
automatic encoding and script creation question
By kronick in forum Video ConversionReplies: 13Last Post: 15th Jan 2010, 13:52 -
MVTools & AVISynth script question with FFDShow
By Gnodab03 in forum Software PlayingReplies: 7Last Post: 8th Jan 2010, 20:05 -
Avisynth Script Question
By MegaTonTerror in forum Video ConversionReplies: 4Last Post: 22nd Aug 2009, 22:28
