A standard PAL 16:9 DVD (720x576) I made gave disappointing results on a cousin's Toshiba TV. It slightly flattened the result and cut off parts of the sides. His TV was set to 'Wide', which I think is what some would label 16:9. Other options in settings were worse. However, his other TV gave correct results.
I examined the Toshiba user guide and found a setting option called Autoformat, which was ON. I had to leave his house before I could watch the entire DVD again with this OFF, but a quick test seemed positive.
Is this likely to have been the cause of the aspect problem please?
Terry, East Grinstead, UK
Assuming the DVD is OK, don't see what else it could be.
Is the DVD OK?
autogk wrong aspect ratio
By codemaster in forum Video ConversionReplies: 8Last Post: 5th Feb 2011, 10:09 -
Wrong Aspect Ratio
By weathervane in forum Capturing and VCRReplies: 11Last Post: 18th Aug 2010, 23:18 -
youtube aspect ratio wrong
By Perdu in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2010, 20:51 -
wrong aspect ratio using ripbot
By magmo in forum Video ConversionReplies: 2Last Post: 12th Mar 2009, 09:15 -
wrong aspect ratio ???
By clickit in forum ComputerReplies: 3Last Post: 7th Dec 2007, 03:49
