  1. Member Bronx's Avatar
    Dec 2003
    Bronx, New York
    Hi all,
    I built my HTPC and would like to upgrade my CPU. I need a stronger CPU to convert mini DV tapes and dvd's to divx or mp4 at a faster speed.
    I was reviewing the following:
    Intel Pentium E6600 3.06GHz LGA 775 65W Dual-Core Desktop Processor
    Intel Pentium E6800 3.33GHz LGA 775 65W Dual-Core Desktop Processor
    Intel Core2 Duo E7500 2.93GHz LGA 775 65W Dual-Core Processor
    Intel Core 2 Quad Q8300 2.5GHz LGA 775 95W Quad-Core Desktop Processor
    My PC specs are:
    Windows 7 Ultimate
    Antec Fusion (Black)
    Dual 2 Core 2.2 ghz
    1tb SATA 7200 RPM and 500 gig 7200 RPM and 250 gigs for the OS
    4 GIG ddr2 800
    HP 16x DVD(+/-)R/RW DL LightScribe drive
    Intel DG43GT Motherboard
    Thanks in advance.
    When it sounds too good to be true, it usually is!!
  2. If you're going to be doing h.246 encoding get a quad core.
  3. Member Bronx's Avatar
    Dec 2003
    Bronx, New York
    Thanks for the reply. I dont know much about CPU 's. How fast would it encode 30 minute clip?
  4. It depends on the encoder and settings you use. Anywhere from a few minutes to several hours.
  5. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    I'm sure it depends on the source (res+bitrate) and the target settings.
    I'd choose CPU #4.
    *** Now that you have read me, do some other things. ***
