    Aug 2009
    Australia
    Can anyone help me with this please i am trying to convert this Blu-ray movie to fit onto a single BD-25 disc its a VC-1
    and keeps coming up with this error.
    Directshowsource: timeout waiting for graph to start.
    (E:\temp\ripbot264temp\job1\getinfo.avs,line2)
    thanks.
    USA
    Not enough information. Have you used the program successfully before? What program are you ripping it with? Are you ripping it to the hard drive? If the HDD drive rip is successful, have you tried running tsMuxeR to separate out the correct tracks, then muxed them and used that with RipBot? Are you using a different HDD for storing the rip and a different one for the processed file?
    A fair number of main movies will fit on a BD-25 disc by themselves, without using RipBot.
    Aug 2006
    Are you using Ripbot 1.16.3? If not, why not try updating to that version and see if it solves your problem.
    Aug 2009
    Australia
    i am using version 1.13.0 didnt have any problems with other movies.
    i have ripbot, and the ripped version which is 32gig both on the same drive and the destination is also the same drive.
    i use anydvd to rip the movie to my HDD.
    it fails after gathering information before it even starts to recode.
    ill try a newer version.
    Aug 2006
    I think ripbot 1.16.3 has that problem fixed. Try it and see if it does
    Aug 2009
    Australia
    the latest version of ripbot 1.16.3 is running so it seems to be working i guess ill know for sure in about 30 hrs.
    cheers all.
