    Dec 2007
    Brazil
    I really liked the program but would like yellow subtitles ...
    How to change color?
  2. I don't use that program and have no idea if and how it allows you to select the subtitle colors. However, it's easy enough to do to the DVD itself after having created it. The easiest way is by using DVDSubEdit. Here's the guide:
    http://download.videohelp.com/DVDSubEdit/Guides/ChangingColors/Guide.htm
    Nov 2003
    West Texas
    As far as I can tell, you can change font, font style (regular, bold, italics, etc) and size of the fonts, but not the color in AVStoDVD.
    Dec 2007
    Brazil
    I think there's no way even if I only use the vobsub plugin, there goes that normal, only built, no problems, thank you all.
  5. There's no possibility to change subtitles format from the GUI right now. But editing subs format is in the ToDo list.
    Bye
    MrC
    AVStoDVD Homepage
  6. Member ricardouk's Avatar
    Mar 2005
    Portugal
    you'll need to overide the sub profiles created by subtitle creator in avs2dvd, heres a small screencast:
    i'm no expert in making screencasts but you'll need to located the avs2dvd install folder and follow the video
    http://videos.sapo.pt/BY7SjL8FV8704PzUvvp4
    I love it when a plan comes together!
  7. Originally Posted by _MrC_ View Post
    Bye
    Of course, I was referring to hard-encoded subs.
    For authored subs, as Kerry56 said, you can already change font, size and aspect but not color (see 'Preferences'/'AuthoringBurning').
    Bye
    MrC
    AVStoDVD Homepage
