I'm trying to convert a video format. Ogm, VP7 video codec and audio ogg, I have the K-Lite Mega Codec pack installed, I can display the result usually, only to convert the AVStoDVD, the time it opens the encoder HCenc 0.25, the error saying it has no decoder and does the conversion ... k-lite does not support conversion of VP7? What decoder do I use?
Another question, does not support Avstodvd. rmvb?
and why every time I open a video it appears to be asking such a mistake I want to continue, the error related to chacarcteres?
Thanks![]()
you appear to have a space in 'avstdvd.rvmb'
have u tried SUPER? i found that program on my own a few years back, i've really loved it, though i recently read other opinions which werent so high.. but i think its awesome. i've never had anything but success and outstanding results, though it really has a high learning curve, you will have researched evrything ever written on video encoding by the time u get proficient with it, as everything is really freely adjustable, and u need to know what works with what and how
and some of the built in settings and tasks are much slower and less reliable than your own customized settings and internal methods.
its the most powerful tool on the market, imo, it does just as it says on its website "super does for free what other programs can't do for money"
if anything can open and edit your file, super can.. you'd be hard-pressed to find something Super can't do
i myself use the codec pack 'pure codec', and nothing else. if u have other ones installed it could conflict and error.. i dont know if its ur problem, but maybe..
good luck -
Thank you for your attention, then, follows the log:
<21/10/2010 01:32:15>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: PAL
DVD Titles number: 1
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: DVD
DVD Menu: No Menu
Output Folder: C:\Users\ADM\Desktop
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
Video Resolution: 1
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
PAL SpeedUp: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 128
Keep DVD Compliant Audio: 1
Normalize Audio: 0
DVD Audio Language: EN - English
DVD Subs Language: EN - English
DVD Subs Font: Arial 18pt Bold
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: D: TSSTcorp CDDVDW SH-S223C SB05
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Save General Settings: 0
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
TITLE 1 SOURCE FILES
Video: C:\Users\ADM\Documents\ADM\Filmes\saw 1\Jogos.Mortais.1.BDRip.VP7.OGG-TheSeeds.ogm
Info: VP7 - 899 kbps - 680x382 - DAR 1,78 - 23,976 fps (CFR) - - 1:39:04 hours - 142537 frames
Audio 1: C:\Users\ADM\Documents\ADM\Filmes\saw 1\Jogos.Mortais.1.BDRip.VP7.OGG-TheSeeds.ogm
Info: Vorbis - 64 kbps - CBR - 2ch - 48000Hz - 1:39:05 hours - Internal
Subs: C:\Users\ADM\Documents\ADM\Filmes\saw 1\Jogos.Mortais.1.BDRip.VP7.OGG-TheSeeds.srt
[MediaInfoLib - v0.7.35]
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("C:\Users\ADM\Documents\ADM\Filmes\ saw 1\Jogos.Mortais.1.BDRip.VP7.OGG-TheSeeds.ogm", CacheFolder="C:\Users\ADM\AppData\Local\Temp", VFR=false)
Audio = A2DAudioSource("C:\Users\ADM\Documents\ADM\Filmes\ saw 1\Jogos.Mortais.1.BDRip.VP7.OGG-TheSeeds.ogm", CacheFolder="C:\Users\ADM\AppData\Local\Temp")
Video = Video.ConvertToYV12
#Using DGPulldown/HCenc to upsize FPS
Video = Video.Lanczos4Resize(720,576)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 1-pass
Target Video FileSize: 4207,5 MB
HCenc Parameters: -ini "C:\Users\ADM\AppData\Local\Temp\DVD_1_Jogos.Morta is.1.BDRip.VP7.OGG-TheSeeds.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\ADM\AppData\Local\Temp\DVD_1_Jogos.Mortai s.1.BDRip.VP7.OGG-TheSeeds_1.avs
*AVSRELOAD
*OUTFILE C:\Users\ADM\Desktop\DVD_1_Jogos.Mortais.1.BDRip.V P7.OGG-TheSeeds.m2v
*LOGFILE C:\Users\ADM\AppData\Local\Temp\DVD_1_Jogos.Mortai s.1.BDRip.VP7.OGG-TheSeeds.HCenc.log
*MAXBITRATE 9000
*1PASS
*BITRATE 5937
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 60
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<21/10/2010 01:32:45>
PROCESS ABORTED DURING TITLE 1 VIDEO ENCODING OPERATIONS.
CHECK LOG FILE <C:\USERS\ADM\DESKTOP\DVD_1.LOG> FOR MORE INFO.
Log file created by AVStoDVD Release 2.3.2
Encoding to VP7
By tb582 in forum Video ConversionReplies: 10Last Post: 20th Apr 2009, 21:32 -
mpeg2 decoder available quicktime alternative for use with MPEG Streamclip
By mattiebrownoz in forum Video ConversionReplies: 0Last Post: 9th Apr 2009, 19:08 -
Problem with mpeg2 decoder.
By tehuser in forum Software PlayingReplies: 5Last Post: 24th Mar 2009, 18:59 -
Mpeg2 decoder library for developers
By Ufit in forum ProgrammingReplies: 3Last Post: 27th Dec 2007, 02:56 -
Quicktime Alternative no longer has MPEG2 decoder for Streamclip use?
By vidvoo in forum Video ConversionReplies: 8Last Post: 15th Nov 2007, 17:42
