  1. Hi there,
    Is there a method to batch convert avi files to burn in the filename of the avi - just like you would add a permanent subtitle?
    Any method would be cool, even a hint if it is possible at all. Thanks in advance!
    Greets,
    Frank
  2. Member olyteddy's Avatar
    Dec 2005
    To do it for the whole vid, you'll have to re encode the whole video. Could you do it as an introductory clip, or an end credit?
  3. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    A batch file like this:
    :LOOP
    for %%A in (*.avi) do (
    IF NOT EXIST "%%~dpnA.avs" (
    echo.AVISource^("%%A"^)
    echo.Subtitle^("%%A"^)
    ) > "%%~dpnA.avs")
    SHIFT
    @if %1X==X goto END
    @goto LOOP
    :END
    exit
    will create an AVS file for each AVI in a folder, with the filename as subtitle.
    See http://avisynth.org/mediawiki/Subtitle for options.
  4. You're awesome! Thanks a million
    Btw, is there a possibility to have all the avi files (with subtitle) concatenated in one AVS script? So that the result is one AVI file with the subtitles burnt in for each segment?
  5. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    AVISource("vid1.avi").Subtitle("vid1.avi") ++\
    AVISource("vid2.avi").Subtitle("vid2.avi") ++\
    AVISource("vid3.avi").Subtitle("vid3.avi") ++\
    AVISource("vid4.avi").Subtitle("vid4.avi") ++\
    AVISource("vid5.avi").Subtitle("vid5.avi") ++\
    AVISource("vid6.avi").Subtitle("vid6.avi") ++\
    AVISource("vid7.avi").Subtitle("vid7.avi") ++\
    AVISource("vid8.avi").Subtitle("vid8.avi") ++\
    AVISource("vid9.avi").Subtitle("vid9.avi")
    Of course, they all have to be the same frame size, fps, audio rate, etc.
  6. Amazing, didn't know that. Thanks a lot!
    I think I can manage to adapt the BAT script you posted earlier to have it done automatically for a whole directory full of AVI files, but I'm not sure how I can write "if this is the last file, don't echo "+++\" ... would you be able to help me out with that?
  7. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    To do that is stretching batch files a bit. Though I'm sure it could be done.
    (have a look at the whacky things people do in alt.msdos.batch.nt)
    I'd just do this:
    echo.AVISource^("%%A"^).Subtitle^("%%A"^) ++\
    ) >> "combo.avs")
    And just delete the last 3 characters manually.
    If you want to do the whole thing programmatically you should look into more powerful scripting languages, like perl.
    (I really should use perl more, but a few batch tricks and word processor macros do most of what I need to make scripts.)
