Hi
I've got a Panasonic DMR-ES20D UK version and am using it to convert some old VHS tapes to DVD. I'm sure it has some kind of video stabilizer or TBC built into it as it fixes some old VHS tapes which didn't play well before, such as shaky video and wavey signal. Basically its good for some tapes, however there are a few tapes which I am trying to copy which play perfectly if connected to the TV but when connected to he DVD recorder, the built in stabilizer/tbc adds a jitter to the video which just kills your eyes when trying to watch it D:
So basically all I want to know is if there is any way I am able to turn off the tbc when its not needed as there is no option for it.
Thank You![]()
I know of no way to turn off any TBC but if you push the DISPLAY button on the remote you can turn various NR settings as well as change the progressive mode. Personally I leave NR on and use VIDEO for mode.
Ok thanks
I know about the NR settings and they reduce the noise nicely so I prefer them on
For the shaking, i'll probably just have to copy the disc onto the computer afterwards and use some stabilization filter or something to fix it.
Thanks Again
Did you try manually adjusting the VCR tracking?
Life is better when you focus on the signals instead of the noise. -
Yep, I did that and it does reduce the shaking but doesn't remove it completely.
Like I said it plays perfectly when connected direct to the TV so the built in TBC in the recorder seems to not like this tape
What about following possible reasons:
- VHS is Macrovision protected ( you can see symptoms here http://www.xdimax.com/dvd/dvdredpro.html )
- VHS is NTSC (no PAL used in UK) and VCR can't sync with it.
Picture enhancer/TBC/stabilizer?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 10:01 -
New to tbc - need advice on optimizing Panasonic svhs ag1970 w/tbc
By yoda313 in forum Capturing and VCRReplies: 8Last Post: 15th Jan 2011, 10:43 -
JVC S-VHS machine w/ stabilizer "on" plus inline TBC = disaster?
By justin81 in forum RestorationReplies: 8Last Post: 7th Oct 2009, 01:23 -
Would a Digital Video Stabilizer work for a PAL tape in an NTSC vcr?
By ChaunceyK in forum Newbie / General discussionsReplies: 1Last Post: 21st Sep 2007, 13:42 -
panasonic VCR tbc + external tbc - any use ?
By abbymat in forum RestorationReplies: 13Last Post: 15th Aug 2007, 09:29
