I have been cutting a few scenes from an MKV file using Avidemux 2.5.3. I have done so, as I have read somewhere, only from keyframe to keyframe using the << and >> buttons in Avidemux (is it normal they all are exactly every 10 seconds?). Also when opening the file I got the following confirmation dialog:
H.264 detected
If the file is using B-frames as reference it can lead to a crash or stuttering. Avidemux can use another mode which is safe but YOU WILL LOSE FRAME ACCURACY.
Do you want to use that mode?
To which I answered NO. And then another confirmation dialog:
Index is not up to date
You should use Tool->Rebuild frame. Do it now?
To which I answered YES.
When saving I set the options:
Video: Copy
Audio: Copy
Format: MKV
The resulting file appears to be almost completely fine but there are some scenes (from a keyframe to another keyframe I noticed) in which the audio is out of sync. In a 6:30 minutes long file it happens only once, from 5:30 to 6:10, and in another 10:00 minutes long file it happens twice, from 2:10 to 2:40 and from 8:30 to 8:50.
Does anybody know where could be the problem and how I can fix it?
Problem solved.
The source file was actually a MOV produced by a Canon S95 camera: I then converted it to an MKV using Handbrake.
I tried instead converting the source file to an AVI using XMedia Recode; I then edited the AVI using VirtualDub and everything went fine.
Loss of Audio Sync after cutting (Avidemux)
By Maverick-X in forum EditingReplies: 4Last Post: 14th Oct 2011, 16:12 -
Audio out of sync in MKV file.
By Colin-uk in forum Video ConversionReplies: 14Last Post: 14th Oct 2011, 13:50 -
Avidemux - DVD/VOB file to MP4/MKV - Audio problem
By prabath_fun in forum Video ConversionReplies: 0Last Post: 7th Sep 2010, 11:32 -
Anyone know of something that will change audio sync in a TS or MKV file?
By Emanef in forum Video ConversionReplies: 2Last Post: 12th May 2009, 10:26 -
AVIDemux 2.4.1 cutting audio or maybe video sync issue
By ColdFusion2 in forum LinuxReplies: 9Last Post: 11th Sep 2008, 11:27
