Closed Thread
Results 1 to 9 of 9
  1. i've never really had problems playing videos on my system thanks to the latest k lite mega codec packs but recently, i've been having problems playing this certain set of TS files that i recently downloaded. i love using windows media player and so i always make it a point to play videos there. my problem is: the ac3 audio plays (you can hear it playing), but you can't see the video at all. its like WMP treats the file just like an audio file (you can even turn on the visualizations lol ).
    well, i have installed haali media splitter and made sure that it has ts support enabled. the haali tray icon even appears when i play the ts file so i assume haali is the splitter that is being used.
    i even tried downloading some sample transport streams ("http://www.dododge.net/roku/hd-test-streams/football.ts") and they turn out to play perfectly.
    its really bothering me that i can't play these files so any help will really be appreciated! please and thank you
    Oct 2005
    666th portal
    try identifying what they are. use mediainfo in text mode and paste the results here.
  3. General
    Complete name : I:\Miggy\Movies\720p-1080p\I.Am.Legend.Alternate.Version.Blu-ray.REMUX.1080P.VC1.TrueHD.DD51-SiLU\I.Am.Legend.Alternate.Version.Blu-ray.REMUX.1080P.VC1.TrueHD.DD51-SiLU.disk1.ts
    Format : MPEG-TS
    File size : 4.30 GiB
    Duration : 29mn 37s
    Overall bit rate : 20.8 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : VC-1
    Format profile : AP@L3
    Codec ID : 234
    Duration : 29mn 37s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 fps
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Audio #1
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : 129
    Duration : 29mn 36s
    Bit rate mode : Constant
    Bit rate : 640 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 136 MiB (3%)
    Language : English
    Audio #2
    Menu ID : 1 (0x1)
    Format : AC-3
    Format profile : TrueHD / Core
    Codec ID : 131
    Duration : 29mn 36s
    Bit rate mode : Variable / Constant
    Bit rate : Variable / 640 Kbps
    Maximum bit rate : 3 366 Kbps / 640 Kbps
    Bit depth : 16 bits
    Language : English
  4. The video is Microsoft VC1. WMP should be able to play that. Make sure the "Download codecs automatically" option is enabled.
  5. ohhhhhhh aww man the option has always been checked hmmmm maybe there's a problem with the file?
  6. or maybe its my system? any suggestions?hmmm..
  7. Member yoda313's Avatar
    Jun 2004
    The Animus
    I know you want to use wmp but try playing it with mpchc or vlc. If they can't play it there might be something wrong with the file itself.
  8. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    Originally Posted by _migz_ View Post
    General
    Format : MPEG-TS
    Duration : 29mn 37s
    You must be kidding........... Have you read and understood the forum rules?
    *** Now that you have read me, do some other things. ***
    canada
    Please do not ask for help on illegally downloaded movies,this thread is closed.
