I have a sony dcr-hc42e camcorder with small tapes and i need to stream recorded tapes to my laptop and save it to my hdd
the problem is my laptop did not detect my camcorder at all , i pluged the usb cable and the cam is not detectable.
is there any solution to save video from tapes to laptop ?
the only way to transfer those tapes to the computer in full quality is to connect the cam and laptop using a firewire cable and port. on the cam it's called the DV port.
aedipudd, even if my laptop can not even recognize my camcorder ???
i am saying so because connecting or disconnecting the camcorder to my laptop via USB port seem to do nothing , looks like it is not detectable at all , maybe it needs a driver or something, but i did a thorough search in the internet and i found no drivers to this camcorder!
so are you sure the Firewire cable will be able to transfer data from my tapes to my laptop ? and how can i know if my laptop has a firewire port or not , what does it look like ?
and thanks for your help
google firewire port. completely different and separate from usb.
will you tell me , even if my camcorder seems to be undetectable , will it work on streaming to laptop using firewire cable ??
We are all here to do what we are all here to do
I have a Panasonic camcorder that is not recognized by USB. It only is recognized by the Firewire port.
I have the same camcorder. USB Driver for WinXP are on the CD that came with the camcorder. I don't know if it works for Windows 7... And as aedipuss said Firewire port will give you the full quality stream of your tapes.
For a laptop, you need a mini Firewire cable (same plug each side). And with this cam, the transfer is only possible with the Sony cam deck. Then you have to get a soft that can do the stream from cam to computer. WinDV works great. Cheers
Sony DCR-HC24 on Windows 7
By slobadaca in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Mar 2013, 10:41 -
Why is virtualdub 32bit much slower on windows 7 X64 than winxp 32bit?
By TigerSoul in forum EditingReplies: 4Last Post: 26th Mar 2010, 16:13 -
Sony DCR-SR47 60GB 60 optical zoom camcorder
By newbe tech in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 25th Jan 2010, 20:17 -
Wanting to get a Sony DCR-TRV740 camcorder.
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 26Last Post: 16th Jun 2008, 20:03 -
Live Video Streaming using Sony DCR TRV22 and IBM T42 laptop
By MESP2005 in forum Capturing and VCRReplies: 3Last Post: 16th Mar 2008, 06:52
