I keep getting Power calibration errors? and then write fails? I am tried different software and everything??
not sure if this link will help.
http://www.megaleecher.net/Fix_Power_Calibration_Error -
Strongly suggest you look at MJA's link. If you live in the USA and Canada, the ONLY reliable media you can buy is Taiyo Yuden (you'll have to buy online) and Verbatim. That's it. Using better media should help. Burning at slower speeds can often fix this problem too. Both are suggested in the link.
*** Now that you have read me, do some other things. ***
Magnum DRW 9500
By Topp in forum DVD & Blu-ray RecordersReplies: 0Last Post: 20th Feb 2009, 21:31 -
error msg when try to record on drw-500
By harryb in forum Newbie / General discussionsReplies: 2Last Post: 10th Nov 2007, 00:57 -
Asus DRW-1814BLT Freezing Computer While Working
By mightymo77 in forum DVD & Blu-ray WritersReplies: 5Last Post: 1st Nov 2007, 11:54 -
New Asus DRW-1814BLT Sata 18x Burning slowly Nero7
By DAVE440 in forum DVD & Blu-ray WritersReplies: 5Last Post: 15th Sep 2007, 02:16 -
ASUS DRW-1814BLT SATA Cables needed?
By Choppa in forum DVD & Blu-ray WritersReplies: 3Last Post: 14th Aug 2007, 00:21
