1)I would like to know what is the best video converter that i can change the settings to what format i want.e.g change the ratio,size of file etc.
2)i also looking for a DVD burner that i can create a menu that can link various file/videos.currently im using Ulead video studio.is there any one better?
I like AVStoDVD as a free solution - high quality encoder, lots of options, basic menus facilities. ConvertXtoDVD is fast, does a reasonable job and handles most formats.
Don't know what you are asking for in question 2. I assume you mean an authoring tool, but that will only do DVDs. Perhaps if you could be clearer in what you are trying to do ?Read my blog here.
Hi pegasus,
thanks for the reply.as for the question 2, what actually i want is a DVD burner software that i can create a custom menu.it something like when we play a DVD,menu will appear & we can scroll down to the option e.g PLAY,SETUP,CHAPTERS etc..
I need something that i can link the subtitle to the videos.
Another thing that i wanna know,some software when i convert to DVD,the output format is different from others.some with VOB,others will be VOB VOT,some mpegs but all are DVD's.confusing... -
DVDs only use VOBs, nothing else. The video is encoded using Mpeg-2 compression, but the container is VOB. The other files are IFO files - text files that contain details about the structure of the DVD, and BUP files, which are backup copies of the IFO files.
If you want an authoring tool that does subtitles and multiple audio tracks etc then you are looking at something a bit beyond the one-click-wonder crowd. I use DVD Lab Pro, which has a reasonable learning curve, and does not convert your videos for you.Read my blog here.
Two questions: Best free video converter & Best free muxing tool?
By milOtis in forum Video ConversionReplies: 7Last Post: 9th Jul 2011, 18:40 -
HELP with Sony DVDArch5 & burning a menu-based Blu-ray... successfully
By jimcornetet in forum Authoring (Blu-ray)Replies: 4Last Post: 20th Jun 2010, 12:14 -
Need to create video DVD with menu & chapters from VOBs. Any suggestion
By mr_tinka in forum Authoring (DVD)Replies: 2Last Post: 4th Feb 2008, 17:26 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36
