Getting increasingly frustrated! I have tons of video footage shot on our Samsung HMX-H205 camcorder (high-def) and I can't get any of it over to a DVD of any sort in a watchable fashion.
The camcorder's footage is shot 1080i60.
Audio on the resulting AVCHD DVD created plays before it's supposed to in the video.
Help!
[22:48:12] Initialising...
[22:48:12] Checking for new version...
[22:48:13] You have the latest build.
[22:48:13] Consistency check finished!
[22:48:13] Initialization finished. multiAVCHD is ready!
[22:48:13] 1 year and 296 days since multiAVCHD was published.
[22:48:13] 372 people supported it with donations
[22:48:13] and you are the 3602891 one to launch the program...
[22:48:13] Support multiAVCHD to extend its features and keep it going!
[22:48:13] multiAVCHD.dat version: [04010767]
[22:49:05] Audio track #2 name: [HMX200]
[22:49:59] Audio track #2 name: [HMX200]
[22:52:13] Checking for available space and drive types (FAT32/NTFS)...
[22:52:15] Destination [c:]: NTFS, 271152.03 MiB (264.797 GiB) free space
[22:52:15] Temp folder [c:]: NTFS, 271152.02 MiB (264.797 GiB) free space
[22:52:15] Log started for multiAVCHD v4.1 (build 770)
[22:52:15] Selected output mode: AVCHD compatible player (DVD/BD-R disc)
[22:52:15] Processing one title...
[22:52:15] Existing c:\multiAVCHD\AVCHD\ cannot be used as destination folder!
[22:52:15] Output will be written to: c:\multiAVCHD\AVCHD-20101018-225215
[22:52:15] Strict AVCHD folder mode is enabled...
[22:52:15] Processing (C:\Users\Brad\Desktop\CamcorderVideoToEdit\100VID EO\20100608RachelSwimmingSinging.MP4)...
[22:52:15] Pre-processing...
[22:52:42] This title is marked for reencoding / uncropping...
[22:52:42] Encoding process may take 10 min to 10 hours, so be patient...
[22:52:42] *** Initiating video encoding:
[22:52:42] *** Original : 1920x1080
[22:52:42] *** Crop : 0
[22:52:42] *** Resize : 1920x1080
[22:52:42] *** Uncrop to : 1920x1080
[22:52:42] *** Sharpen : 0
[22:52:42] *** Bitrate : 17028 kbps
[22:52:42] *** Frame rate: Original (29.970)
[22:52:42] *** Level : 4
[22:52:42] *** B-frames : 3
[22:52:42] *** Ref-frames: 4
[22:52:42] *** GOP size : 30 (keyframe min. each 2 frames)
[22:52:42] *** Quality : One pass (turbo)
[22:52:42] *** SAR : 1:1
[22:52:42] *** DAR : 1920x1080
[22:52:42] *** Profile : Blu-ray
[22:52:42] *** Encoding : One pass - content: [00:02:09]
[22:52:42] *** Encoding : x264 options: --preset veryfast -B 17028 --interlaced --direct spatial -I 30 --level 4 -i 4 -b 3 -r 4 -m 2 --mvrange 511 -A p8x8,i8x8 --ipratio 1.1 --pbratio 1.1 --vbv-bufsize 15000 --vbv-maxrate 14000 --qcomp 0.5 --threads 2 --thread-input --aud --nal-hrd vbr --sar 1:1 --b-pyramid strict --slices 0 --weightp 0 --rc-lookahead 30 -o "c:\multiAVCHD\_TEMP\multiTEMP-20101018\20100608RachelSwimmingSinging_new.[1920x1080-29.970].264" "c:\multiAVCHD\_TEMP\multiTEMP-20101018\20101018-225242-uncrop-running.avs"
[23:01:10] *** Close to completion - closing preview...
[23:02:06] *** Speed : 6.86 fps (elapsed: 00:09:23 - Realtime x 0.23)
[23:02:06] *** Transcoding successful!
[23:02:06] Detected frame reference count: 3 (max:4).
[23:02:06] Detected video: ID#0:V_MPEG4/ISO/AVC 1920x1080, fps=25.000, ref=3
[23:02:06] Detected audio: ID#2:A_AAC (48000Hz 16bit 2ch 128kbps) Language: und
[23:02:06] NTSC slowdown will be applied to all streams for NTSC compatibility!
[23:02:06] Attempting to convert A_AAC audio track #2...
[23:02:06] Encoding A_AAC to AC3...
[23:02:30] Trying to encode audio with ffmpeg...
[23:02:44] Audio encoded to AC3 successfully!
[23:02:44] Added audio: A_AC3, "c:\multiavchd\_temp\multitemp-20101018\20100608rachelswimmingsinging_new.t2.ac3. scn.ac3.scn.ac3", lang=und
[23:02:44] AR of 16:9 will be set for this title.
[23:02:44] M2TS stream split set at 4000MiB...
[23:02:44] Creating clip and playlist info (tsMuxeR)...
tsMuxeR (Version 1.10.6) output:
Decoding H264 stream (track 1): Profile: High@4.0 Resolution: 1920:1080i Frame rate: 25
Change H264 level from 4 to 4.1
H.264 manual setted fps not equal stream fps. Change H.264 fps from 25 to 23.976
Decoding AC3 stream (track 2): Bitrate: 128Kbps Sample Rate: 48KHz Channels: 2
Processed 3227 video frames
Creation of Blu-ray playlist
Creation of Blu-ray stream info and seek index
Mux successful complete.
Muxing time: 19 sec
tsMuxeR meta:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --custom-chapters=00:00:00.000 --split-size=4000MiB --vbv-len=500
V_MPEG4/ISO/AVC, "c:\multiAVCHD\_TEMP\multiTEMP-20101018\20100608RachelSwimmingSinging_new.[1920x1080-29.970].264", insertSEI, contSPS, lang=eng, level=4.1, fps=23.976
[23:03:03] Media transfer: 00000 -> 00000.m2ts
[23:03:03] Processing playlist...
[23:03:03] Title #1 added: "20100608RachelSwimmingSinging"
[23:03:03] Verifying title...
[23:03:06] Title has: 1 audio tracks and 0 subtitle tracks
[23:03:06] Preparing authoring information...
[23:03:06] Creating NTSC top menu.
[23:03:06] Setting pop-up menu...
[23:03:08] *** [00000.mpls] - Adding pop-up menu [1080p]...
[23:03:08] *** Completed!
[23:03:08] Authoring menu (NTSC).
[23:03:08] Creating title thumbnails for 1 titles (SLI)...
[23:03:15] Using 1 thumbnail/chapter links for title #1...
[23:03:15] *** Extracting 1 chapter thumbnails...
[23:03:15] *** Chapter #1 [00:00:00.000] set for thumbnail at [00:01:04.530]
[23:03:18] Image processing for SLI menu completed!
[23:03:18] Preparing menu pages...
[23:03:18] Encoding static SLI menu page [1/1] [Static title thumbnail].
[23:03:46] Encoding static SLI menu page [1/1]: Chapter page [1/1].
[23:03:51] Encoding static SLI menu page [1/1]: Setup page (audio/subtitle).
[23:03:55] Menu authoring completed.
[23:03:56] Encoding Title List menu page [1/1].
[23:04:15] Setting main menu for 1 titles...
[23:04:15] Go to menu after last title.
[23:04:15] Setting menu properties...
[23:04:15] Selected TV system: [NTSC]
[23:04:15] Processing clip (CPI/CLPI) files...
[23:04:15] Completed.
[23:04:20] Preparing AVCHDTN database...
[23:04:21] Database and index created!
[23:04:21] Done!
[23:04:21] Saving multiAVCHD quick-load project (mpf):
[23:04:21] c:\multiAVCHD\AVCHD-20101018-225215\multiAVCHD.mpf (OK!)
Compilation summary:
Format: AVCHD compatible player (DVD/BD-R disc)
1. 20100608RachelSwimmingSinging [00:02:14]
Overall duration : 00:02:14
Output size : 286 MiB (0.28 GiB)
[23:04:21] c:\multiAVCHD\AVCHD-20101018-225215 folder created (AVCHD/Blu-ray output)!
[23:04:21] Burn its CONTENTS to DVD R/RW UDF 2.50/2.60 disc!
[23:04:22] Launching ImgBurn...
[23:11:21] You may now remove temp folder (c:\multiAVCHD\_TEMP\multiTEMP-20101018\).
[23:11:21] Your compilation contains 0hrs 2min 14sec of video material.
[23:11:21] multiAVCHD finished in 1146.513 seconds (00:19:06.513)!
[23:11:21] End of log.
[23:11:21] Cleaning up...
[23:11:22] Done!
[23:11:22] For technical support, bug reports and questions:
[23:11:22] http://multiFORUM.deanBG.com/
[23:11:22] http://multiAVCHD.deanBG.com/
[23:11:22] http://multiAVCHD.deanBG.com/doom9/
[23:11:22] For latest download links and tools visit:
[23:11:22] downloads/
You could try avchdcoder and see if you get same issues.
Burn AVCHD to DVD5 with DTS High Resolution audio?
By nateo200 in forum Authoring (Blu-ray)Replies: 10Last Post: 24th Jun 2012, 06:21 -
Vegas movie studio 11 -- need to burn AVCHD file to DVD
By malcolm1 in forum Newbie / General discussionsReplies: 14Last Post: 8th Nov 2011, 03:12 -
I Give Up. Can't Burn AVCHD DVD Without Audio Being 4-5 Secs Ahead of Video
By bmccollum in forum Authoring (Blu-ray)Replies: 8Last Post: 21st Oct 2010, 09:32 -
Are the AVCHD and H264 the only HD format to burn the HD DVD?
By coody in forum Authoring (Blu-ray)Replies: 7Last Post: 3rd Sep 2010, 23:47 -
how to burn avchd on dvd-r in high definition for BR set top playback?
By masterpug in forum Authoring (Blu-ray)Replies: 32Last Post: 15th Aug 2010, 17:47
