Alright so I have a video in which I wanted to crop out 3 parts of, and then join those parts together, leaving the rest of the video behind. I've done this a few times before, but the same problem happens.
I cut out each piece at the same framerate etc, and name them part1.avi, part2.avi, and part3.avi
Then I go file "open", open up part 1.... then I go file "append", grab part 2, then "append", and grab part 3.... I do a direct stream copy as I don't need to re-compress the 3 parts, just join them together.
However, every time, it ends up like this:
PART1--PART2--PART3--PART3.
Why does part 3 always end up on there twice at the end??
Thanks!
Virtualdub might auto append if you have named them like that. You can try deselect "Automatically load linked segments" when you open the avi.
Yup, that fixed it. Thank you kindly!
While I'm here, maybe you know: Virtualdub is great when I want to crop out part of a video file, but what program does the same thing (as easily) for MKV/h.264 etc.? Like all the 720p stuff... Virtualdub says .mkv is an unknown/unsupported file type.
Cutting video sections with Virtualdub without recompressing
By rantpolicy in forum EditingReplies: 11Last Post: 16th Apr 2012, 06:48 -
Easy edit DVD video cutting out unwanted stuff without recompressing
By deadp0et in forum EditingReplies: 6Last Post: 7th Feb 2011, 07:49 -
need help cutting and joining avi files in virtualdub
By granturissimus in forum EditingReplies: 3Last Post: 31st Jan 2011, 02:53 -
virtualdub: Cutting video in batch mode?
By zzyzx2 in forum EditingReplies: 2Last Post: 21st May 2010, 14:18 -
Simple MPEG2 Cutting/Joining Question
By thefiddler in forum EditingReplies: 4Last Post: 21st Dec 2009, 15:39
