Hi,
I used to have a miniDV tape camera and to make DVDs from it I would use Adobe Photo Elements to capture the movie, edit it and put it on a DVD. I would keep the AVI file so that I would have it as a back up.
So now I have moved to a AVCHD camera and a memory card.
I want to be able to put the movies into Adobe and edit them for DVDs as well (more often as I would like to re-use the memory card). So I plugged in the camera and all the files came over separately as MTS files. Is this the best way to do this? Should I convert the MTS files into something else? I can play them over Adobe and put them in a project to edit them but I also want to have a back up copy.
Hopefully I explained that well enough that someone could help me.
Thanks.
Stacy
If you can play them in adobe than you don't need to do anything else. Edit them directly from the mts files.
For backup simply burn the original mts files to dvd and/or copy them to an external harddrive. Those will be your original sources just as your old minidv tapes used to be.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
The MTS files are your backup. They will be high definition AVCHD (h.264) and contain all the camera metadata (date, time, camera settings,etc.). If DVD is your goal, Adobe Elements will downsize to 720x480 16:9 and output MPeg2 DVD.
It is also possible to maintain high definition by producing a so called AVCHD Blu-Ray disk on DVDR or BD/BE media for playback on a Blu-Ray player. See MultiAVCHD tutorial.
Or you can author a full Blu-Ray to a Blu-Ray writer.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Canon HF200 Useless So Far
By HF200Remorse in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 31st May 2010, 19:55 -
Canon HF200 and Premiere CS4
By tapaza in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 22nd Feb 2010, 07:49 -
2 Mics for the Canon HF200... How?
By juststarted in forum AudioReplies: 3Last Post: 25th Nov 2009, 15:23 -
Buyer's Remorse on a Canon HF200
By Genison in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 28th Aug 2009, 22:53 -
Canon HF11 or HF200?
By David97 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd May 2009, 10:09
