Here is my problem: I can't scale down the movie in APCS5. I've done it before where I took this high resolution clip and drop it in the timeline then in the preview screen I was able to drag the corners and adjust it to my desired screen size which was 720x480. Now I can't seem to "simply" scale it down by dragging down the corners to my specific size. What can I do? Reason why I want to do this is because If I put "Scale to Frame Size" the "HD" video will be like wide screen, something I don't want. If I could drag the corners like a previously did I can adjust it myself and not have it be wide screen.
Results 1 to 1 of 1
ffmpeg automatic scaling possible?
By richiedood in forum Video ConversionReplies: 14Last Post: 2nd Jul 2011, 08:52 -
the effect of scaling to frame size (PP)
By metathran in forum EditingReplies: 4Last Post: 18th Feb 2010, 13:59 -
PowerDVD: HD Scaling problem
By Kim Jespersen in forum Software PlayingReplies: 5Last Post: 10th Apr 2009, 05:44 -
Adobe Premiere. Difference between frame size and scaling?
By vid83 in forum EditingReplies: 4Last Post: 13th Dec 2008, 21:57 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17
