hey everyone - can this machine transfer from tape to disc or does that not exist?
I don't think so. That appears to be just a VHS and DVD player, though it may also be a VHS recorder. Even so, all in one units won't copy commercial tapes to DVD or commercial DVDs to VHS tape because of copyright protection limitations.
You can use a DVD recorder to back up non-commercial VHS tapes, but the results may not be good. Because VHS is analog, there are problems backing up tapes to digital formats, such as DVD, unless the VHS unit has some form of stabilization as in a TBC (Time Base Corrector) that will clean up the VHS signal. Commercial VHS tapes are also usually copyright protected.
And Janowski, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
And welcome our forumsLast edited by redwudz; 18th Oct 2010 at 11:40.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
Sorry, I must have searched and got the wrong model.
But the copyright protection problem still exists with commercial tapes and discs.
thanks guys - does the analog mean that the transfer would take a while to compress?
Janoski
If your are speaking of commercial tapes that may very well have CP
That Machine, I would say No
Do you have a VHS player or can get one [6 heads are not necessary or needed] There are DVD units that will record anything And do not require any PC, box, TBC, or software
Transfer of real bad tape to pc and restore
By mammo1789 in forum RestorationReplies: 96Last Post: 9th Mar 2012, 22:38 -
DCR-HC42 Transfer Still Images from Tape
By MichaelRD in forum Newbie / General discussionsReplies: 1Last Post: 6th Sep 2010, 22:09 -
Telecine Machine for 8mm film super 8 film transfer to dvd
By igotregister in forum Capturing and VCRReplies: 5Last Post: 2nd Feb 2009, 15:50 -
DV tape damage during transfer
By syberkill in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 22nd May 2008, 21:03 -
How to transfer my stripe HD in another machine?
By Jo The Veteran in forum ComputerReplies: 9Last Post: 27th Jan 2008, 00:27
