Hi all,
I have a slight problem which I hope somebody here can help me with. I use a Samsung C5500 BluRay player to stream video to my TV. FFW and RW are unavailable, but I can use arrow buttons to skip forwards/backwards in steps. However, I have a number of avi files where this is impossible and I assume this must be due to missing timing information. Is this a fair assumption?
If so, is there any way I can process the video files and insert new timing data into them? I know I can convert them of course, but I'd like to know if there is a way to avoid that and which is maybe faster than converting them would be?
There are a few AVI repair tools in the Tools section ( see menu to your left <-- ), however it might be as simple as loading the file into AVI Demux and letting it take whatever action it suggests, or loading them into Virtualdub and doing a Direct Stream Copy to a new container. If the issue is as simple as a damaged index then any of these should fix the problem.
Read my blog here.
Thanks a lot, I'll give that a go asap! I really do think it is just a matter of missing index data, since the files play perfectly both on the pc and through the BD player.
Thanks again!
can't join lossless AVIs - incompatible data format message
By spicediver10191 in forum Video ConversionReplies: 7Last Post: 25th Apr 2012, 07:42 -
Corrupted WMV Files - Header is missing critical data
By Avide in forum Video ConversionReplies: 4Last Post: 6th Jul 2011, 04:01 -
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 08:00 -
Copying the in sync timing of language1 to out of sync timing of language2
By mago1978 in forum SubtitleReplies: 0Last Post: 19th Jan 2009, 15:05 -
Fill in missing parts of mpeg with "dummy" data
By nagihcim1 in forum Newbie / General discussionsReplies: 3Last Post: 15th Sep 2007, 00:33
