I am such a novice I shouldn't even be posting here because I probably won't understand the answers. sigh. But I'm going to try:
I am trying to edit some videos. I just bought a Sony DCR-SX63. I used to use Adobe Premiere 6.0 or Windows Movie Maker to edit home movies (but I would capture them from the real tape through a firewire the old fashioned way and never had any problems). Now apparently the videocam clips are mpegs and WMM doesn't support them. I tried Adobe and it gives me some message about not supporting the rate:
"Unable to open that file. File was recorded at an unsupported rate. Supported rates are 11kHz, 22 kHz, 32kHz, 44kHz, and 48kHz."
All I want to do is have an easy way to edit the videos. These are vacation videos and kid videos for my use only. From what I tried to understand from these forums, I have to run some software to change the format of the individual videos clips? This would take forever I think- I have hours from a trip to Ethiopia and I'm not about to go file by file converting them.
What can I do? Is there ANY video editing software that supports these files? Is there anyway to convert a whole folder to the right format?
Please answer in very easy terms.![]()
ok, I have no idea what you're talking about
I looked at the properties and it says "movie clip mpg"
on the bottom of the camera it says NTSC 7.2V (I'm not sure what is important or what anything means so I'm just giving you whatever I got
i don't see "kHz" anywhere.. I'm sorry I'm such an idiot. I have no idea even where to look.... -
As mentioned twice before, download MediaInfo. Open your troublesome media file with it,
and put it into view/text mode.
All the gory details will be revealed. Copy and paste the info into the forum here, so the experts can review it.
https://www.videohelp.com/tools/MediaInfo
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
In the future, how many sub-channels could be put into one 6-mhz space?
By Frank-0-Video in forum DVB / IPTVReplies: 13Last Post: 31st Jan 2009, 00:36 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17 -
[Solved]Adobe Premiere Error : Unsupported Audio Rate
By anindyanuri in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2007, 10:33 -
TMPGEnc Plus 2.5 saying unsupported??
By Suprman37 in forum Video ConversionReplies: 10Last Post: 12th Oct 2007, 17:51
