I downloaded a premade AVCHD of a concert. The screenshots show a menu so I'm assuming chapters are already set but the video stream is 7GB and too big for me to put on a USB stick for my PS3. I'm not very familiar with where I can go from here (I've made them, just never modified them). Can anyone tell me where I would go from here? I'll show the info if you need that to tell me what to do. Thanks
What are you trying to do? It should play on your PS3 as it is. It is a bluray file so must be played on a bluray player that accepts AVCHD format.
I love children, girl children... about 16-40
W.C. Fields -
i need the video file broken up, it's too big to put on a USB stick. i thought about converting it but i'd lose the menus. here's the info from the certificate folder. see how there's only one title for the concert? there's two included but the entire concert is on title one and is about 7 or 8 GB
BD9 Blu-Ray Disc Format
Menu & Chapters Included
Title 1 Running time: 01:30:15
VIDEO ATTRIBUTES:
Codec: MPEG-4 AVC/H.264
Container: MPEG-2 Transport Stream
Resolution: 1920 x 1080
Scanning System: 1080i/60Hz
Frame Rate: 29.970 fps
Constant Bit Rate: 11.5 Mbps
Aspect Ratio: 16:9
AUDIO ATTRIBUTES:
Codec: Dolby AC-3
Number Of Channels: 6
Channel Positions: L, C, R, SL, SR, LFE
Sampling Rate: 48kHz
Bit Rate: 384 kb/s
SOURCE:
Pro-Shot (HD 16:9) > HD Satellite Broadcast (1080i, Dolby 5.1) > Dish Network ViP-722k HD-DVR > Component Video Cables (YPbPr) & Optical Cable (s/pdif) > Hauppauge HD PVR 1212 > USB 2.0 Cable > PC > ArcSoft TotalMedia Extreme (.m2ts) > TS Packet Editor 0.301 > ArcSoft TotalMedia Studio > BDMV Folder (BD9 AVCHD)
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 19:09 -
Can't get multiAVCHD to successfully create an AVCHD folder???
By jwmghf in forum Authoring (Blu-ray)Replies: 15Last Post: 17th Nov 2011, 12:37 -
AVCHD on hard drive: creating new AVCHD folder structure
By Phil_W in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st May 2011, 14:46 -
Final Cut Pro 7 exits when importing avchd folder
By jovannig in forum EditingReplies: 0Last Post: 23rd Jan 2010, 17:24 -
AVCHD MTS numbering restarts at 0, impossible to copy to the same folder.
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 16th Jan 2010, 22:11
