  1. devdev devdev's Avatar
    Sep 2003
    hi im looking for an mpeg editing program that will allow me to add titles, inc overlay tiltes, add transitions, fade and make bits darker/lighter
    any suggestions?
    i currently create the mpegs using tmpg enc
    budget up to 200 us$
    Oct 2005
    666th portal
    if you check around and catch a deal, sony vegas studio can be had for around $30. http://www.sonycreativesoftware.com/moviestudiope
    premiere elements is another option.
  3. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    "Thirty Bucks"?
    Oct 2005
    666th portal
    "Thirty Bucks"?
    yes it was 30 at fry's after rebates, 2 weeks ago. it's a fairly common piece of software to go on "sale".
  5. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Have you ever collected on one of those Fry's rebates? Or forget to send it in, or even remembered after eight weeks that you never got it? But you can't find the paperwork and even if you did, you have to be on hold for an hour and then an Indian call center answers, and they require you to restore your computer to factory default first. Hahaha.
    YEAH, I got ISSUES!!!! Hahaha
  6. devdev devdev's Avatar
    Sep 2003
    thank you
    will give it a go!!
