Hi,
I just bought a Samsung C550 player (originally Region 2).
I found the hack for my player, but it doesn't work
I can change the numbers on the grid from 1 to 24, but no combo worked :\
The best is that i didn't write down the original numbers, but i think it was 2,8,10,17,19,21,25.
I'd like to be able to read Region 1 & 2 DVD's...
Any help ?
Thank you very much
Bye
I can change regions on my Samsung C550
1. go to matrix
Grab the remote and press:
-repeat
-fast rewind
-next chapter
-fast forward
-previous chapter
-play
2. Write down which numbers highlighted and which are not
Numbers 1, 2, 3 representing region code
so by changing them you can change your region
use this table:
123
001 first region
010 second region
011 third region
100 fourth region
101 fifth region
110 sixth region
111 seventh region
1 means that the number is highlighted and 0 means it is not highlighted
for example:
region 1 (number 3 highlighted)
region 5 (numbers 1 and 3 highlighted)
3. when you finish press Play button it will switch off your DVD.
4. power on your DVD player and you will see Reset on your screen.
I tried to set 0 region on my DVD but it didn't become region free. You can try it on yours (unhighlight all 1,2,3 numbers)
Region 1 Samsung dvd-vr375 to switch to region free
By catleo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Dec 2011, 11:25 -
Samsung HT-C550 region hack - Please Help!
By LostInOz in forum DVD & Blu-ray PlayersReplies: 3Last Post: 31st Jul 2011, 02:30 -
Samsung DVD-C550
By Spindlewoody in forum DVD & Blu-ray PlayersReplies: 0Last Post: 28th Apr 2011, 01:37 -
region code fot Samsung DVD C550
By samsungdvd550 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Oct 2010, 13:11 -
Region free? - Samsung HT-TZ212
By Lovinda in forum DVD & Blu-ray PlayersReplies: 10Last Post: 16th Nov 2009, 05:33
