Hey,
I want to know if it's possible to re-encode an already encoded video (but this time, having wpredp=0) with the following requirements:
(1) no quality loss
(2) output video size must not vary that much from the original; say 100mb (approx.) increase is fine. I mean, cuz I don't think that wpredp=2 is a major contributor to the compression of the output video right?
I've used mkv2vob and it has accomplished requirement (1) but not (2). The output video size became 1.5x the original.
I need to know if there's a way because this "wpredp option" is causing the video to pixelate and stutter on my PHILIPS BDP-7500.
nope
you have to re-encode and you will lose quality
just re-encode the original source video (i.e. don't start from the encoded video) -
Thanks for your reply,
I don't have the original source of the video, nor do I have that much free space on my computer to convert the video to a lossless compression format and then re-encode it with wpredp=0.
There has to be another way. -
No there isn't. You have to re-encode the encoded video then, and suffer the loss
Decompressing to a lossless format doesn't provide any benefit here , and your player won't play a lossless format (lossless means equivalent to the encoded video, not the original source video - it doesn't recover the lost details or eliminate compression artifacts, and when you re-encode you still incur the generation loss) . Just re-encode directly from the encoded video.
Search for a firmware update on your player. Some companies have updated firmware that allow weightp compatibility e.g. oppo has done this for their BD players
x264 weighted chroma
By hardy in forum Newbie / General discussionsReplies: 0Last Post: 15th Apr 2012, 10:43 -
prediction: "Bulldozer" will be a beast
By deadrats in forum ComputerReplies: 6Last Post: 3rd Oct 2011, 06:37 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
Removing Video Frames Damaged by Flash Photography
By SCDVD in forum EditingReplies: 8Last Post: 20th Mar 2009, 17:35 -
A Recursive Gaussian Weighted Filter For Impulse Noise Removal
By JohnnyMalaria in forum RestorationReplies: 5Last Post: 16th Jan 2009, 10:49
