hello
my dvd recorder does not power up,of course i have tried invain changing the plug fuse.
any suggestions please .
thank you
My experience agrees with your initial efforts: Start with the simple, cheaper fixes. Other simple (hopefully not insulting) suggestions:
o What model recorder is it? Have you checked the owner's manual for hints?
o Do you know for certain it won't work on another power outlet?
o Is the power cord hardwired to the recorder? If not, can you try another one?
o If the power cord IS hardwired, can you check it with a multitester to insure each wire isn't broken internally? (You'll have to open the unit.)
o If you're willing to open the unit, check for another internal fuse or perhaps a circuit breaker to reset.
o Once inside, look for anything that might be burned, loose wire(s) needing to be resoldered, bad capacitors (swollen-looking).
Others may have additional, more useful ideas.
Good luck and let us know if you were able to find the problem and solution!
PotPlayer: no audio switching, no subtitle switching
By Anonymous9843 in forum Software PlayingReplies: 1Last Post: 6th Oct 2012, 22:44 -
Switching to AVCHD
By TheLaserdisc in forum Authoring (Blu-ray)Replies: 18Last Post: 4th Mar 2012, 00:05 -
LG dvx550 keeps switching off?
By aelfheah in forum DVD & Blu-ray PlayersReplies: 0Last Post: 19th Feb 2012, 10:43 -
Plz someone help~ switching audio files in VCL player...?
By OokKyou in forum AudioReplies: 3Last Post: 25th Jan 2010, 23:54 -
DVD Flick causes skips/lags when switching chapters
By takearushfan in forum Authoring (DVD)Replies: 1Last Post: 20th Nov 2009, 23:31
