Dear Jagabo
Thnaks again but, no, I don't have a TV with S-video in. But the camcorder has a colour LCD which works in colour as a camera and on playback. Its just that it displayed monochrome when I had connected, via its own S-video socket, the new S-video cable from the Sky+ box (uncontrollable) S-video out socket.
All very strange.
I will check my other TVs but don't think I've ever seen one with S-video in socket.
Results 31 to 33 of 33
Hi, please download ADVC mini Release Notes and take a look at page 2; you'll find "Video quality settings".
The ADVC capture software has three video quality settings:
- Slider positioned Center (default): it produces .mov files (your case)
- Slider positioned to the left: it should produce MPEG2 files (I suppose this, because I haven't got the ADVC mini)
- Slider positioned to the right: it should produce uncompressed AVI files.
You should positionate the slider to the left; by doing this you'll to get MPEG2 interlaced files, and you'll be able to create your DVD.
In fact the MPEG2 perfectly manages interlaced video; very often the special contents you can find on a commercial DVD are MPEG2 interlaced files
Hello keyboardboy,
I know this is a VERY OLD thread, but I am struggling with the exact issue you did way back in 2010. Did you get this resolved when you received your new ADVCMini?
I am using the Grass Valley software because Final Cut Pro and iMovie did not provide a capture method for the USB2 input. The GV software provides very few settings to prevent this issue.
Any input you have would be very helpful!
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 19:07 -
PC Doesn't Restart Properly
By bevills1 in forum ComputerReplies: 5Last Post: 5th Sep 2010, 22:20 -
Just can't get stabilization work properly.
By Jim Halpert in forum Newbie / General discussionsReplies: 9Last Post: 24th Nov 2009, 12:58 -
Can't get the .TS audio to work properly
By mkvbob in forum Video ConversionReplies: 3Last Post: 25th Jul 2008, 17:04 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58
