Hi.
I have a DVD Player where I play avi movies from a USB stick. The strange thing is that I can't play any avi file which is written with AVI-Mux GUI application. The movie just plays for 7-8 seconds and then stops.
Any suggestion would be helpful.
Thank you !
Results 1 to 9 of 9
I don't think it's AVI-Mux GUI, but maybe your settings (or default settings).
It could be a number of things, like your player doesn't recognize ODML AVI, or needs to be interleaved with audio every 1 frame, etc.
Go to Settings -> AVI file structure (under Output) and try different combos. I'm sure one can work.
BTW - Welcome to the Forums.Last edited by PuzZLeR; 16th Oct 2010 at 12:02.
I hate VHS. I always did. -
Hi.
Thank you for your reply.
Here is an example of an avi file which my DVD can't play:
General
Format : AVI
Format profile : OpenDML
File size : 699 MiB
Duration : 1h 27mn
Overall bit rate : 1 112 Kbps
Writing application : AVI-Mux GUI 1.17.8.3, Feb 16 201019:42:50
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (MPEG)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 27mn
Bit rate : 979 Kbps
Width : 624 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.149
Stream size : 616 MiB (88%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Format_Settings_ModeExtension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 27mn
Bit rate mode : Variable
Bit rate : 123 Kbps
Nominal bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 77.2 MiB (11%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.72 video frame)
Interleave, preload duration : 231 ms
Title : 911_Output
Writing library : LAME3.98r
Here is an example of an avi file which I can play:
General
Format : AVI
File size : 700 MiB
Duration : 59mn 15s
Overall bit rate : 1 652 Kbps
Writing application : VirtualDubMod 1.5.10.1 (build 2366/release)
Writing library : VirtualDubMod build 2366/release
Video
Format settings, Matrix : Custom
Muxing mode : Packed bitstream
Codec ID : XVID
Duration : 59mn 15s
Bit rate : 1 451 Kbps
Width : 720 pixels
Height : 400 pixels
Frame rate : 25.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.201
Stream size : 615 MiB (88%)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
Codec ID : 2000
Duration : 59mn 15s
Bit rate mode : Constant
Bit rate : 192 Kbps
Video delay : 16ms
Stream size : 81.4 MiB (12%)
Alignment : Split accross interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 500 ms -
My guess is your DVD players doesn't like the audio interleaving:
Interleave, duration : 24 ms (0.72 video frame) (doesn't play)
vs.
Interleave, duration : 40 ms (1.00 video frame) (plays)
If Avi-Mux GUI supports "1-frame" interleaving try it. -
Sounds weird, but has your player an "60 minutes" limit for xvid??
*** Now that you have read me, do some other things. ***
MUX Mp3 Into AVI
By onesikgypo in forum LinuxReplies: 4Last Post: 13th Apr 2010, 01:05 -
AVI-MUX: How do I mux avi file with a setting of "preload=512?"
By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 10:10 -
Alternative to AVI-mux GUI?
By badreligionhead in forum Video ConversionReplies: 3Last Post: 8th Dec 2009, 12:30 -
Question why AVI-Mux GUI cuts down file size
By jimdagys in forum EditingReplies: 2Last Post: 16th Apr 2009, 03:18 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 05:42
