Hi there, please can someone give me advice which software is best for simple video "scene cut editing" without affecting original video file ?
for example, i often fraps World of Warcraft, and then i need tu delete some scenese to save some gigabites on mi HDD for later use. But i dont want to "scratch" original video file framerate, quality, resolution etc....
I use VirtualDub for FRAPS, but AVIDemux would probably also work. With VD, just do your cuts and use 'Direct Stream Copy' and it won't re-encode or change any of the parameters of the video.
And welcome to our forums.
thanks for welcome and for advice
i tryed virtualdub before but i didnt mentioned 'Direct Stream Copy' option, thanks again
Avidemux--What is the difference between CUT and DELETE when editing?
By gumbygum in forum EditingReplies: 4Last Post: 19th Aug 2010, 13:36 -
Problem with particular scenes in mkv
By johnnysv in forum Software PlayingReplies: 1Last Post: 27th May 2010, 09:10 -
Question how to delete files that won't delete
By jimdagys in forum ComputerReplies: 18Last Post: 9th Sep 2009, 14:09 -
I'm wanting to cut some scenes and add some fade-ins to a DVD video.
By Ryan J in forum MacReplies: 4Last Post: 17th Apr 2008, 09:42 -
Editing AVI, VirtualDub Error, Codecs not working.Can i delete afew scenes?
By UmmAddan in forum EditingReplies: 5Last Post: 23rd May 2007, 06:29
