What programs, aside from Vob2mpg and Vob2mpgPro can be used to extract unmodified mpegs from DVDs?
I have an issue with them, that's why I want to try something different.
TIA
Results 1 to 11 of 11
NeroVision - been using it for years without a problem.
If you decide to give it a shot:
Load Disc, or Disc Image (ISO, NRG, etc)
Fire up NeroVision and select an Import Folder (More -> Configure... ->Folders tab and select a directory)
Make DvD -> DvD Video -> Import Disc -> Select drive with Disc (or Image)
All the disc titles will appear - select all those you want and hit "Ok"
When NV is finishes, all titles will appear on the interface, but most importantly, all associated .mpg files will be ready in your Import folder.
Believe it or not, you can use this software and method to pull streams from even non-formatted discs created from other software/hardware!
It sets up great DvD projects and is a good capture utility too. Good tool.I hate VHS. I always did. -
As an aside, I did mention NeroVision as an excellent, reliable VOB->MPEG-2 converter, and it is, but I don't recommend it for editing. An MPEG dedicated editor like TMPGEnc, Womble or VideoReDo would work better here.
Then again, pulling streams and editing them are two different sciences.I hate VHS. I always did. -
Thanks for the replies. I think I should've been a little more specific. First, the issue I'm having with Vob2MpgPro is here: https://forum.videohelp.com/threads/326664-Vob2MpgPro-loss-of-audio-on-seek-forwardI
What I'm trying to do is concatenate all mpegs (28 in the case of PP DVDs) into one big one.
I did install several programs that were recommended above, but only tried Nerovision so far. I did get the individual mpegs extracted just fine, and was able to combine them into one big video that doesn't exhibit audio loss, but I'm not sure how much, if any, encoding nero vision does. (see attached pic) Since the resulting file will be encoded and reduiced with video4fuze to 224x176 for my daugghter's video player, that may not matter much, but I like to have as few encoding/recoding steps as possible.
TIA -
Hi again,
Originally Posted by aurgathor)
Don't use NeroVision with editing. It's likely to re-encode. Use a dedicated MPEG editor for any edits, joins or even cuts, virtually lossless with VideoReDo, TMPGEnc MPEG Editor or Womble AFTER NeroVision pulled out the streams first.
Originally Posted by aurgathorI hate VHS. I always did.
want to capture directly to ffdshow mpeg-1 or mpeg-2 for dvd
By wolfdogg in forum Capturing and VCRReplies: 10Last Post: 10th Jan 2012, 07:23 -
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 08:52 -
This is a minefield! (converting mpeg to mpeg for DVD)
By uth in forum LinuxReplies: 29Last Post: 18th Nov 2007, 15:04 -
MPEG-1 to MPEG-2 to DVD Advantages/Disadvantages?
By louv68 in forum Video ConversionReplies: 4Last Post: 7th Jul 2007, 16:51
