We are in the process of launching our eLearning website which will contain video lectures. I am trying to find the best .vob to .flv converter and have so far tested 10 but none of them preserves the quality of the original .vob video.
After converting the file into .flv, viewing the file on full screen has very low quality unless playing it at about 75% smaller screen. Can anyone recommend a solution, regardless how large the destination file will be (but certainly not as large as the .vob). many thanks in advance for your kind assistance.
Results 1 to 10 of 10
actually, from the list of encoding formats, i saw the h264 .flv but didnt think it was an actual .flv format. many thanks for your help!
just tried using the h264 .flv.
unfortunately, same result.
any other suggestions?
there is an option for YouTube .flv. do you think this could be the one? -
But what are you converting with? What settings? You can get VERY good quality with h264 video if you just use good converters and settings like high enough bitrate and resolution.
i havent played around with settings. i dont even know where to find the settings option for some reason. what settings should i use?
It might help if you told us what software you are using.
i am using a recommended encoder called Emicsoft.
under settings, i have the following options:
Video Settings
Encoder: H264
Frame Rate: 15fps
Resolution: 320*240
Video Bitrate: 512kbps
Audio Settings
Encoder: AAC
Channels: 2 Channels Stereo
Sample Rate: 44100 Hz
Audio Bitrate: 64 kbps
Many thanks
Best way to convert VOB to AVI or other type without any quality loss
By mikej411 in forum Video ConversionReplies: 4Last Post: 16th Nov 2011, 12:56 -
Home video to flv - quality loss and file size
By Bain80 in forum Video ConversionReplies: 3Last Post: 20th Aug 2011, 19:08 -
Can I get VOB to smaller file size with no loss of quality?
By Joolz2020 in forum Newbie / General discussionsReplies: 17Last Post: 23rd Aug 2010, 13:11 -
FLV Input Plugin for Virtualdub lets you save as AVI with no quality loss?
By gumbygum in forum Video ConversionReplies: 7Last Post: 1st Aug 2010, 14:08 -
Get .vob dvd to youtube w/o quality loss
By kenmtb in forum Newbie / General discussionsReplies: 6Last Post: 24th Jul 2009, 02:28
