Hi,
How does VOB2MPG handle subtitles? (evt. difference with the PRO version)
Here's what I tried: Have a DVD iso with classic structure (AUDIO_TS, VIDEO_TS), when playing this using VLC, I can view, select, deselect subtitles.
I processed the VIDEO_TS folder with VOB2MPG, the converting is perfect, but I lost my subtitles?
I did some searching here, but only found links to other external tools/programs.
Is this a limitation of the free version?
In case the PRO version supports subtitles;
Will I be able to add external (srt) subtitle files to the stream?
Thanks,
Erwin
Please take a look at: https://forum.videohelp.com/threads/319805-VOB2MPG-Subtitles?highlight=subtitles
Are you using IFO mode or VOBSET mode?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Hi ChrissyBoy,
Thank you for replying;
I've had a closer look at the configuration tab, however I can't find any pointer to IFO or VOBSET mode?
So unfortunately without clarification, I can't answer your question.
What I can tell is that I set my preferred subtitle language to Dutch, Flemish.
Would it be possible to embed multiple subtitle languages?
Thanks,
Erwin
VOB2MPG Pro / Win 7 Pro 64-bit Service Pack 1 Problem?
By Rich_A in forum SVCD2DVD & VOB2MPGReplies: 21Last Post: 2nd May 2011, 15:06 -
vob2mpg pro
By maxone71 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th Dec 2010, 17:41 -
Vob2mpg pro
By cowboyup910 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jul 2010, 07:03 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
Ebay purchasing question
By yogart in forum Off topicReplies: 1Last Post: 25th Jan 2010, 22:24
