I'm having real problem figuring out an easy way to do this.
Basically, I want to convert videos from my digital camera to fit a certain file size using SUPER. I really like SUPER for its speed and flexibility with regarding to handling any file type, but it has some user-friendliness problems.
My most common scenario is converting 1 hr of 640x480 digicam video (from a Canon SD1200), to a file that fits on a regular CD (700MB). Or 2 hrs to 700 MB.
What I do now is blind trial and error, playing around with various output containers, bitrates, etc. Is there any really good settings I should use to optimize the best video quality I can get for this target file size? Maybe some good existing guides I can read?
I know some other converters does have a friendly feature that lets you input the desired final file size and then does everything itself, but I'd like a little more control and understanding of the process.
Use a bitrate calculator. Its file size = bitrate x runtime. There are plenty available in the tools section on the left of the screen.
Convert DVD to ca 700 MB avi using what?
By younso in forum DVD RippingReplies: 2Last Post: 9th Feb 2011, 18:57 -
How to email and receive video clips more than 10 megabytes in size?
By coody in forum Video Streaming DownloadingReplies: 21Last Post: 11th Dec 2008, 05:07 -
Convert MP4 to WMV using SUPER
By bdr13278 in forum Video ConversionReplies: 6Last Post: 21st Aug 2008, 13:19 -
Super 8 film convert to cd
By joe8915 in forum Newbie / General discussionsReplies: 6Last Post: 5th Jan 2008, 08:52 -
Convert mpeg-4 to wmv with super
By Kalash109 in forum DVD RippingReplies: 2Last Post: 17th Nov 2007, 07:14
