I saw something like this when I was using x264. Apparently, it is due to setting the target bitrate higher than necessary. I was just want to make sure... will it affect the final output?Code:2pass curve failed to converge
Edit: Sorry I can't give any more info. I'm on a different computer :/.
Results 1 to 10 of 10
Yes, your final output will be smaller (lower average bitrate) than you requested.
reduce qpmin , (the minimum quantizer) and it should allow you to achieve higher bitrates
default is 10, so try something lower e.g. --qpmin 1 -
What that's telling you really is that you've selected too high a bitrate for your source.
Okay, thanks. It's fine if it simply means that the target bitrate is too high (and that x264 will adjust).
Why don't you use CRF encoding? It's faster, you always get the quality you specify, and the minimum file size for that quality.
With bitrate based encoding you select a bitrate and the file comes out with whatever quality the encoder can deliver for that bitrate. With quality based encoding (CRF) you select a quality and the file turns out with whatever bitrate is required for that quality. If you were to encode a video with CRF and it came out to some particular bitrate, then encoded the source again with a 2-pass encode at the same bitrate, the two files would look nearly identical.
x264 for Blu_ray: 2pass or crf?
By wiseant in forum Video ConversionReplies: 3Last Post: 2nd Jan 2012, 15:12 -
Blackberry 3G 9330 Curve Encoding
By mark63534 in forum Video ConversionReplies: 2Last Post: 20th Jan 2011, 13:35 -
failed dvd deinterlacing with mencoder x264 encoding. help
By link626 in forum DVD RippingReplies: 9Last Post: 3rd Jan 2010, 14:59 -
X264:How do you encode in 2pass ?
By themaster1 in forum Video ConversionReplies: 9Last Post: 25th Apr 2009, 17:29 -
File sizes getting bigger with x264 2pass
By ivan_hoe in forum Video ConversionReplies: 6Last Post: 19th Apr 2009, 08:42
